Question about Dual Electronics CECT P168 Cellular Phone
Wont charge my phone wont charge in the outlet charger or the usb cord and i shuts off and only turns on with the wall charger but doesnt charge
  • 108 Answers
It might be the battery. cause batteries on cell phones only last for so long [depending on how long you've had it] or you might just have a bad phone. go to the phone company where your phone is from, and tell them about it, and they'll probably give you a new phone.
Posted on May 23, 2009
    President:
  • 3,433 Answers
First- run battery dead
Second- turn phone off while charging
third- wrap an ice cube in a washcloth to keep the battery cool while charging.rest the battery side iof phone on the washcloth. It's always better to charge the battery w/phone off and battery kept cool.
Good luck and use the wall charger.
It charges somtmes but only 26% now it wont charge and wont turn on i have changed cords and plugs nothing works please help
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
charges-somtmes-but-only-26-now-wont-c42sdu52tip34gjoftdmfcql-4-0.png before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
The attached link is to an eBay listing that has a compatible wall charger sold in the US for $5.99 shipped free
LCD Battery Charger for Samsung Galaxy Mini GT S5570 i5510 S7230 S5330...
Nov 10, 2015 | Samsung Galaxy GT-S5570
My nook hasn't been turned on or charged for a few months because we lost the charger. We got a new cord and using one of the wall ports we have. Its been on the charger plugged into the wall outlet for...
I read somewhere that all phones and tablets will or already are able to charge from the USB port of your PC.
I don't know if this is 100% true so, you should check it out for your Nook.
Hope this helps.
Feb 26, 2015 | Tablets & eReaders
Can I charge my Craig Power Bank model CMA3121a from a wall outlet, rather than the computer?
You need a mains USB charger, it is a standard 5volts device with a minimum of 500ma. They are easily available. Plug the USB cord into the charger instead of the PC.
Sep 25, 2014 | Computers & Internet
Jensen smpv 4gbs
Teneale,
I tlooks as if possibly you might have a defective unit. I did some research and you wouldn't be the only one. Either that or maybe try a diffrent USB port, maybe even a usb to wall outlet charger....see if that works. If not I would say its defective.
Jan 02, 2014 | Audio Players & Recorders
Ebay phone wont charge
while holding phone upright in you hand look on the side in the lower left corner - open the "tab" This is where you charge the phone with both a wall outlet & a car charger.
Mar 02, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Iphone starts up for 5 seconds then shuts off and wont charge
what charger are you using?
if usb
try wall charger as usb wont charge when in restore mode unless the phone is on
Nov 17, 2009 | Apple iPhone Smartphone
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
PSP chager
Try a different outlet in the wall, it might be the outlet, if it isn't the outlet, maybe it's the power cord or the battery. If it's not that, then it's your PSP. You'll have to send it to sony for a new one if you want it replaced and if youve had it for over year you're going to have to pay $90. ------The fact that it turns off when the USB DC-in is connected and that it will not power up without the battery lead me to think that either the USB charging cable is just not supplying enough amps to run the psp standalone nor charge the battery very quickly, or something is odd in the PSP itself. I'm guessing when you plug something into the DC-in socket and it detects 5V then it switches to that as a source, if the USB cant supply the current it wants then it shuts down (just a guess).
May 06, 2009 | Sony Battery Charger for PSP
Black jack 2 wont charge or turn on
take out the SIM and micro sd and turn on the phone. then shut it off again, replace sim and micro sd then turn back on. DONE! **works on samsung jack too!!!
Apr 26, 2009 | Samsung BlackJack II Smartphone
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
226 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
