Question about Casio Parts Cash Register PC Desktop
Power sypplay in casio ecr.
Main power sypply blow fuse.ifined the short ic pq1cg203.I can't gate in ethopia plese tell me replace this part thankyou.
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    A link to the .pdf datasheet file is http://www.digchip.com/datasheets/parts/... Unfortunately any links on that site want to sell you thousands of the part. Use the application notes to check surrounding circuitry to make sure something else is not at fault. So you don't kill a new part when you put it in. Check ebay to maybe find the part as a single item, listings change daily, if you don't find it at first don't give up too easily.
  • 46 Answers
Have you checked the local electronics parts store like Radio shack?
Posted on May 24, 2009
How to connect pc to casio se-c6000 cash register
Question is how to connect PC with Casio SE-C6000 Cash Register. Answer is very easy and simple. This ECR is POS system and has capability of FTP . Download any FTP software from net. Go to ECR program 3 . Press 798 and sub Total Key. enter local network area unique IP address for this ECR starting with 192.168.1.10 as( 192168001010) an example and must be not conflicting and within the range of local area IP Adresses. then press CA/Amt. Key. then 255255255000 for sub mask and press CA/Amt Key again..Then 192168001254 as gate way then press CA/amt Key again and sub Total Key to finalize. Connect PC with network cable in RJ45 slot on ECR. Turn the mode key on Reg Mode for normal operation. Now on FTP software which is already installed on your PC open and put host ID IP address of your ECR. User Name is "SCTHRD" and Password is : "OTTFFSSENT" then Enter . You will see all program of ECR in folders. I hope it will help your need . Ibrahim Azhar
Apr 01, 2012 | Casio Parts Cash Register PC Desktop
The fuse inside the head keeps blowing when i turn power on, and Im getting continuity between the white & black from the transformer
Looks like the main power IC is shorted!
Check the main power amp IC and replace it if there is a short between their pins!
Hope that helps you out!
Jun 23, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
My car Amp keeps blowing the main fuse, How to find the short?
Hello A4en1, hi, A short circuit need not be burned, the short usually are semiconductors such as ICs and transistors or diodes, I suggest you replace your IC power amplifier.
Mar 29, 2010 | Sony Car Audio & Video
I have a Casio PX-310 on the service bench . I
As you probably know the regulator also supplies power to the other ICs on the board. If the fuse keeps blowing that means that one of the parts drawing power is shorted. By looking the pin configuration up for each IC you can find which one is the + and which one is the- etc. The faulty IC will be showing voltages on the other pins where they shouldn't be. That is usually the defective part. You will also want to check parts that are related to or in the same circuit. The worse case scenario is that the main IC is shorted. Without the schematic its a long arduous troubleshooting procedure but it can be done and I just thought I would suggest it. I mean know pffence and just wanted to help somewhat.
Jul 09, 2009 | Music
I can't gate this spare pare pq1cg203
Hi. Which model is it from? You can usually repair the power supplies rather than replace them.
May 23, 2009 | Casio Parts Cash Register PC Desktop
Short Circut, blows fuses instantly.
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Jul 28, 2008 | Durabrand 5.1 Surround Sound Computer...
Fuse keeps blowing
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
Sep 06, 2006 | Panasonic CT-32SX12 32" TV
My tv power does not come on
This set uses a switching power supply. Usually when there is a short on the output side of the switching transformer the supply will just shut down and refuse to operate but normally will not blow a fuse. If the fuse blows suspect a problem with something shorted on the input side of the switching transformer such as I801 regulator IC, diode bridge D801,or other shorted component. Perhaps someone else could tell both of us any other part that could cause the regulator to blow and should also be replaced to prevent regulator failure in the future.
Jun 23, 2006 | Sylvania 6427TE 27" TV
Casio Parts Cash Register PC Desktop Logo
55 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
