Question about Digidesign Command 8 - USB Control Surface for Pro Tools TDM and LE Systems with 8 Motorized, Touch ... (99001210100)
Headphone jack in command 8 plays in one ear while in stereo.
The headphone jack is working in mono and not stereo. Why and how and how much will it take to repair the HP jack? Thanks.
  • 33 Answers
Its due to the compatibility of your headset.... i dont know how much it costs... if you give in a showroom it costs a lot..
Posted on May 23, 2009
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
Jan 21, 2012 | Sennheiser Audio Players & Recorders
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
EV-510 Television: I want a small mono headphone set for my casio ev-...
You can actually plug a stereo headset into a mono jack and it will usually play the audio thru the left ear piece.
May 18, 2010 | Casio EV-510 Television
BR 8 headphone jack
This may also sound stupid but; have you tried a different set of headphones? If you have never used the headphone jack there might be a chance that the contacts inside the jack are dirty from airborn pollutants such as cigarette smoke or cooking smoke. Another good example is if you have a flute or silverware laying around in the open , they will tarnish from the sulfur dioxide in the air. Try spraying a very small squirt of contact cleaner on a stereo plug and plugging and unplugging it into the jack. Make sure you do this with the power turned off. If that doesn't work, do it to the jack itself. Only use a very small amount. If that doesn't work you may have a bad solder joint in the connections to the jack or a circuitry problem. The jacks sometimes a have a built in switching circuit to defeat the signal when phones are plugged in and sometimes the jack fails. Hope this gives you some ideas.
Oct 30, 2009 | Boss Micro BR Digital Recorder
No sound out of one of the earbuds
YOU HAVE A STEREO JACK, LOOKING AT THE EAR JACK THERE ARE 2 COLORED CIRCLES AROUND THE STEEL EAR JACK WHICH DESIGNATE STEREO, ONE COLORED CIRCLE IS MONO-ONE SIDE, IF YOU HAVE TRIED SEVERAL DIFFERENT SETS THEN YOUR EAR JACK IS NOT MAKING A GOOD CONNECTION TO YOUR STEREO EAR JACK AND ONLY GIVING YOU SOUND TO ONE SIDE(MONO), AND MIGHT NEED REPAIRED
Feb 20, 2009 | SanDisk Sansa e260 MP3 Player
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
Headphone jack
I have the same problem with my DJ 30, and it exists with several different types of headphones.
I am thinking about trying a mono to stereo adaper, where the plug is mono, and the ear phones are stereo. I don't know if it will work or not.
Dec 16, 2007 | Dell DJ MP3 Player
Computers & Internet Logo
177 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
David Payne
David Payne
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
