Question about Canon CanoScan 4200F Flatbed Scanner
Canoscan 4400F & Vista
I followed all the instructions but cannot get the scanner to work.  I get an error message about the TWAIN.
  • 8 more comments
  • Tirleton Nov 03, 2007
    Same problem with receiving a twain error message
  • Anonymous Nov 11, 2007
    I have the same problem with a Twain error message only I have Windows XP
  • Anonymous Nov 12, 2007
    Same here, with a Canoscan N640P. I assume it's too old to be compatible with Vista, but I was hoping for an updated driver or some solution so that I don't have to go scanner shopping.
  • sixtyseven Dec 27, 2007
    PrestoPage Manager cannot 'see' the Canoscan 4400f scanner although other programs can.... I need OCR which is supplied on the disc for the Scanner which although advertised as Vista ready, required a download from the internet to work.
  • kenboy111 Jan 06, 2008
    cannot find scanner.. twain problem
  • Anonymous Feb 16, 2008
    I have a CanoScan Lide 20 Flatbed I am trying to install into my Microsoft Windows XP computer, but the Twain error came up. The computer says it cannot run the scanner program because of the Twain error. I've tried to download a free computer scan, but it's not working. What can I do to fix this error?
  • Anonymous Feb 17, 2008
    my canon 4400f scanner will not scan after depressing the copy or any other buttons. I have down loaded the latest driver from the canon web site
    but the problem persists. Can you help me.
    george r.
  • hugo 2 May 11, 2010
    Please, i need help
  • Anonymous Mar 19, 2014
    Twain error
    Win7 64bit
Cause 3: The application program is not TWAIN-compliant. Solution: Start ScanGear from an application program that is TWAIN-compliant.
An error message appears and the ScanGear window fails to appear. Solution 1: Reattach the USB cable and AC adapter. Only use the supplied USB cable and AC adapter with the scanner. Solution 2: Attach the USB cable to a different USB port on the computer itself (not a hub). Solution 3: If a USB hub is used for the connection, do not use it. Attach the cable to a USB port on the computer itself (not the hub). Solution 4: Install the software from the accompanying CD-ROM. Solution 5: Scanner may not be selected. Select your scanner from [Select Source]. Solution 6: Make sure that the application is TWAIN-compliant. You cannot use ScanGear with an application that is not TWAIN-compliant. Solution 7: Quit ScanGear if running the scanner driver with another application program.
Posted on Jan 09, 2009
  • 09harwoca Jan 09, 2009
    Now just to figure out if my scanner is TWAIN compliant.
    Scholar:
  • 53 Answers
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Posted on Dec 06, 2007
  • GUILLERMO ORTUNO
    GUILLERMO ORTUNO Dec 06, 2007
    Make sure to download all the available drivers too.
Canoscan 8800f error as ''cannot connect with scanner''
I had the same problem with a new canoscan 8800f. I found by connecting the scanner USB lead to a USB 1 .1 port instead of a USB 2.0 port the problem seems to have been was solved. I was fortunate to have both. Originally it was just USB 1.1 ports on my PC, but I added USB 2.0. I don't know how you solve the problem if you only have 2.0 ports.
Oct 24, 2009 | Canon CanoScan 4400f MultiFunction Color...
I need a twain driver for my canoscan N670U Everytime Im going to scan its say TWAIN ERROR WHY IS THAT>??? I have Windows Vista.. Please Help
The driver is on the cd that came with your scanner. If you do not have the cd then you should be able to download it from Cannon's website.
Dec 20, 2008 | Canon CanoScan N670U Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
TWAIN error
Connect the scanner and re-install the driver. That should fix it
Jul 10, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Have uninstalled and reinstalled software for CanoScan LiDE60 and still coming up with 2 error messages - "cannot communicate with scanner" and " unable to open TWAIN source". How do I...
Are you scanning from Toolbox? Make sure the correct scanner is selected in the Settings section.
What OS is this? Try scanning from various applications.
Does the scanner react at all at any time?
Make sure you have installed ScanGear and not just Toolbox.
Apr 30, 2008 | Canon CanoScan 4400f MultiFunction Color...
CanoScan 4400f
uninstall all drivers and software that cam with the scanner, and then try installing the software again before connection the scanner... this is a problem when there are two different twain drivers, look for C:\Windows\twain_32\CNQ4803(2) see if there is a driver in there.
Dec 22, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
1,579 people viewed this question
old marine
old marine
