Question about Biostar computers10: Main Board MB-5800TUC-A with AMD CPU (TC80016) Motherboard
Mother board reset buttom?
My computer wouldn't turn on so i replaced the PSU, motherboard, RAM, and hard drive.  what is my next step?  and i didn't replace the parts with the same manufacturer.  i started with Emachine and used Biostar replacement parts.
  • novis Oct 22, 2007
    i tried disconnecting everything and i did not hear any beeps.  and how do i check the compatibility of the motherboard FSB and processor?
    i even took it to a firedog specialist and he wouldn't even touch it!
    i think it is time to get a new computer and throw this one out the 3rd floor window!
    Scholar:
  • 155 Answers
I assume you have the fan of your power supply working indicating that power is OK.
Disconnect everything from the motherboard leaving only the processor, fan and power. If you don't hear any beep means that you have a problem with either the motherboard or the processor.
PS Verify compatibility of motherboard FSB and processor.
Posted on Oct 19, 2007
  • Massimo Ardito
    Massimo Ardito Oct 23, 2007
    If this computer was working before and now you don't have any beep means that the motherboard or the processor are bad.
    In the process of replacing parts you should verify the compatibility of your motherboard with the processor and the memory, everything else is not critical.
    To this check you need to know the motherboard type (Usually is written between the PCI connectors) like in this picture
    then you have to find the manual in internet and you can see the FSB (Front System Bus) speed.
    Same thing with the processor, on top of it there is a number that if you put in Google will give you all the details. Look for FSB and see if it's the same of your motherboard.
    On the same manual of your motherboard you will also find what type of memory you can use.
    If you find this procedure too heavy, just send me the numbers of motherboard and processor and i will find the documentation for you.
MY COMEPUTER KEEP RESTARTING I WILL LIKE 2 KNOW Y
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory hope this helps
Sep 02, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
My computer cannot turn on the power, and i found a red led always on at the center near the rear portion of the mother board. is that something wrong with the mother board or just the supple power is...
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 26, 2011 | Shuttle K45 Intel based barebone system...
Pc wont boot, MCP73PVT board, i have checked the ram, processor, heat sink and psu,cmos batt and still no joy, its starts for 4 seconds and turns off, all fans come on but nothing else no beeps
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 21, 2011 | Packard Bell (181368) Motherboard
I have tried 2 cases and 3 powersupplies and i continue to get no response fro my mother board. I have new ram and an AMD Anthlon II processor
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
May 16, 2011 | Biostar A780L3L AMD 760G Socket AM3 mATX...
My pc mother board is intel d865gbf/d865perc. It starts and faile and turn off. It will not start soon. So what would be the problem?
Test or replace your PSU power supply unit preferably with a heavy duty one with plenty of wattage remembering that with any added hardware your computer will use more power/wattage eg:more RAM ,bigger hard drive,slave drive
One bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 14, 2010 | Computers & Internet
Power loss after 2 seconds from booting up.
Best solution I can think of is Step by Step
Remove those items again and Step by Step, 1 by 1 install each item.
If each item installs ok one by one, then leave in one item at a time. Slow process yes, but you might find which item is causing the conflict.
If you install smething an the machine fails Remove it and the Item before it, then install the Item that failed and try it again.
If it fails then it could be the item not the PSU.
If it fails because of all the items... Then you may need to upgrade your PSU
May 20, 2010 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
A8n32-SLi Deluxe - Will not boot
your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
Nov 15, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Regarding intel desktop mother board no 865
Remove all drives connection from Motherboard.
Check the PSU..(Power Supply)
If PSU ok, Then problem with RAM / Mobo
Clear CMOS memory by removing the jumper & then puttting it again=> Check MOBO's manual for this.
Try Replacing RAM ..
Best luck.
Jun 23, 2008 | Intel Motherboard
Computers & Internet Logo
54 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
