Question about RCA HD61LPW175 61" Rear Projection HDTV
NO PICTYURE OR SOUND LIGHGTS ON FRONT COME ON BLINK FIVE TIMES THEN GO OUT
JUST REPLACED LAMP NO PICTURE OR SOUND LIGHTS ON FRONT COME ON THEN BLINK FIVE TIMES THEN GO OUT.
  • RCA Master
  • 8,617 Answers
Thats a common problem with the RCA ATC336 Power supply when the capacitors fail on the AC in power board. You can get the repair kit at the following link which will usually repair that symptom.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
Posted on May 23, 2009
I have replaced my Projector lamp, i have had a picture but has shut down and now will not give me a picture and led light blink five times, do i know i didnt reset the lamp setting when i first got my...
hi,
You have to check the lamp ballast supply board. If the Lamp ballast board is faulty the it will burn the new lamp installed. 5 blinks means the lamp is faulty. can be caused by faulty lamp ballast. To deal with the lamp ballast you should need a good knowledge in electronics. Because electric shock risk is involved. Also you need a new lamp
ok
Sep 07, 2011 | Sony KF42E200 TV
Have sound no picture?
if the fan is cutting off and ON there is a problem with your power supply unit.
and this may also affect your other systems on the unit
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
SONY KDF70XBR950 TV. NO PICTURE OR SOUND. FIVE FLASHING RED LIGHT
5 times blink code means Lamp Driver error that can be problem of ballast supply or Lamp.
How old is this TV? Have you replaced Lamp recently?
Service manual of TV can be downloaded from HERE for small fee.
Let me know your finding to provide you more info.
Thanks.
Sep 11, 2009 | Sony Televison & Video
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
I have a samsung HL-S4266wx/xaa and about a month ago the screen changed colors to a negative like a photo. so i turned it off and then back on and five minutes later there was a buzzing sound then the...
This is something that cannot be easily guessed at. There may be a failure in part of the power supply, and on one of the processor boards.
You will have to have the Samsung service rep do the necessary repairs on your set.
Jerry G.
Apr 28, 2008 | Televison & Video
Lamp bulb burned out I install a new one but still no picture
The ballast board may need to be replaced as well as the lamp. The set should give an error code such as blinking lights from the front button assembly. You need to count the blinks and take note if there is a pause between blinks. (example) an error code of 34 will go blink blikk blink, pause, blink blink blink blink. This process may repeat itself a few times.
Oct 29, 2007 | Philips 50P8341 50" Rear Projection...
Picture turns off still have sound
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then? - Sarah
Jul 30, 2007 | RCA HD50LPW175 50" HDTV
RCA HD61LPW175 61" Rear Projection HDTV Logo
390 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
