Question about HP Pavilion dv4000 Notebook
HP Pavilion dv4000 won't turn on/freezes
Everytime i turn on my HP Pavilion dv4000 it will freeze without fail.
Sometimes it won't even turn on at all, the light is on to show the power is on but there is no noise (fans etc) and just a black screen. Ive tried taking the battery out, unplugging all USB sockets, trying with or without the power adaptor connected and it still happens.
Occasionally if i leave the laptop for a day, and i plug the power adaptor in, it will boot up. However i usually only get as far as getting to the desktop before it freezes (sometimes it freezes before it even finishes to boot). When it freezes the cursor freezes and nothing changes on screen untill you hold the power button down to shut it down.
I have a feeling the power source is broken, any ideas on what it could be?
thanks Andy
  • kitch86 May 23, 2009
    Thanks Joe for that solution, ill have somebody check it out. Hopefully won't be too expensive to fix.
    As for logging into safe mode. It froze before i had the chance to select safe mode on the menu
  • HP Master
  • 5,660 Answers
I believe it's the DC Power Jack, that is causing the problems. This jack is where you plug your AC adapter into the laptop. (Power adapter)
There can be many unseen issues with the jack, or it's mounting on the motherboard, that cannot be seen from the outside of the laptop.
The jack itself, is a small rectangular object, and the inside body of this jack is made of plastic. Then there is a rectangular metal shell, that surrounds the plastic inner body.
Let me show you,
http://www.megaemarket.com/dcpojacoforh6.html
(You can click on the photo to enlarge it. It isn't the clearest example of an image, when enlarged, but gives you more of an idea of what the component structure is)
The thick round metal pin in the middle of the jack, is the Positive connection. As you can see from the rear view, the pin attaches in the middle of that plastic inner body. Also looking at this view, the
L shaped flat metal prong, that is connected to this metal pin, is soldered to the motherboard. (It looks just like the L shaped prongs on the side, but you are looking at a rear view of it, not a side view)
The metal 'frame' that surrounds the plastic inner body, connects to the round outside shell, that surrounds the thick metal pin. To help explain further, the outside part of your AC adapter plug, fits tight up against this round outside shell, that I'm trying to explain.
This shell is the Negative connection.
Looking at the back view, the two flat L shaped metal prongs sticking up, are soldered to the motherboard.
I felt this explanation would help give you a better grasp, of what I'm about to explain.
Perhaps this jack is damaged.
Perhaps the thick metal pin's attachment to the inner plastic body, has broken loose, and has now cracked the solder joint for the L shaped prong on the back. (Solder joint to motherboard)
Perhaps the outside metal frame L shaped prongs, have had their solder joints cracked.
If a solder joint is cracked, (Broken), there may be no connection, or an intermittent one.
One more item. Some laptop motherboards had a bad design. Let me explain with this crude example.
For this example, think of the laptop motherboard, as being a 1 foot square. (It isn't. It's irregular shaped)
Now along one edge, attach a 2 inch square. (It's all one piece though) In this 2 inch 'Peninsula', attach the DC Power Jack.
Sometimes this 'Peninsula' can crack, and break away from the main body of the motherboard. If it does, it can break circuit traces.
Circuit traces can be thought of as very flat, thin, copper wires.
These traces connect the power jack to a circuit, that charges the battery, and senses when the battery is fully charged. If there is a problem here, the sensor circuit will read faulty information.
It will sense that the battery is fully charged when it isn't, and also sense that there is no AC adapter plugged in, therefore it will result to using battery power. (Battery isn't charged. Power fades out quickly)
Posted on May 23, 2009
  • joecoolvette
    joecoolvette May 23, 2009
    Thank you for the rating! I also wanted to come back, and help mentally
    prepare you for the labor cost, IF, the DC Power Jack is the problem, or
    a broken DC Power Jack motherboard 'area'.
    If you can find a tech that will replace the power jack, or solder broken solder joints, you'll be doing good. I've seen advertising online, but have no knowledge of the quality. Most of the so-called 'Techs' now, are nothing more than parts changers. For a DC Power Jack, they want to replace the entire motherboard.
    Granted, if the power jack motherboard area is cracked, replacement of the motherboard is needed. But to replace, or solder broken solder joints,
    this is unwarranted.
    Typical cost of soldering broken solder joints, ranges from $90 to $125.
    Replacing the DC Power Jack? $100 to $150.
    The reason the cost seems so high, is that the tech has to completely
    disassemble the entire laptop, down to just the motherboard in hand.
    Then solder cracked solder joints, or replace the jack.
    Motherboards range from $250 on up. Labor is usually $175.
  • 108 Answers
1. Try logging in SAFE MODE
2. If done tell me. We'll take it further
Hp pavilion dv4 notebook pc freezing up every day and making a grinding sound
I'd say you have a disk going bad. Get it replaced under warranty or you are probably looking at a new system.
Quickly back up any valuable data!!
Sep 12, 2010 | HP Pavilion dv4000 Notebook
Installed new mother board to hp dv4000 laptop all went well but after 10 min ish the computer freezes and has to be forced to shut down like it is getting hot and will not reboot with the display working...
is that an original mobo from the manufacturer? if not or yes i think one of the chips might be getting burnt due to a short circuit...claim a warranty repair or replacement... it might be one of the voltage controller chips or capacitors that was burnt... might b a dust issue too
Jun 14, 2010 | HP Pavilion dv4000 Notebook
My HP Pavilion won;t str up. I turn it on. I then
If the system turn on and off and again on automatically, sometimes the problem is in GMCH. ie in the graphic chip. There are other reasons also. You have nothing to do unless you are a chip level technician. Contact me if you are. Make a reply for this because I will get satisfaction by it.
Apr 19, 2010 | HP Pavilion dv4000 Notebook
No audio driver for xp
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46934-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=468789
download from hp this driver to your my_documents folder and install the software for the driver... then restart your computer
does this work... solution
or goto start > control panel > system > device manager show up
look at your audio device in the list... does it have a yellow explaination point.. no driver installe
a red mark mean on the audio device means that the sound chip is bad... and you need to ship the board to a repair shop ... or rma the laptop for repair if still under warranty
also go under the bios to be sure the sound is turned on .. there sometimes is an option to turn off the sound functionality
Sep 25, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 motherboard freezing
There is a chip under the pc card cage that gets cold solder points and ends up breaking loose. The motherboard will need to go on a special rig to be resoldered. It would be faster to just purchase another motherboard on Ebay and install it. The motherboard part number is located in the Ram memory compartment. There are repair firms out there that are capable of repairing these but I am unsure of what the cost would be. I will include a service manual link below to guide you in the disassembly of the laptop.
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Aug 06, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
My Hp dv4000 freezes when i turn it on although power is on
Had the same problem... push on the bottom left hand corner of the computer and see if that makes it unfreeze if so... you have a bad coldsolder issue on the MOBO.. get it replaced or serviced... its a PITA (pain in the ***)
Jun 14, 2009 | HP Pavilion dv4000 Notebook
HP dv4000 not turning on.
try removing out the battery and disconnect the power supply for a minute or two. this would reset whatever memory there is
Jan 12, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 touchpad problem
Im having the same problem. It didnt start until i had to turn my lap top upside down and such trying to get the battery to work, taking it in and out and so forth.
I push down on the left hand side by the touch pad and it works fine. If i dont press down, my typing will not show, music will not play, the whole pc freezes even the time on it.
Oct 21, 2008 | HP Pavilion dv4000 Notebook
Freezes when jostled
sounds like a connection to the hard drive may be loose.
No matter what it is it will have to be taken apart to fix.
Nov 19, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
1,431 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
