Question about Standard Horizon Boating
Can't reset depth finder for correct depth readings
We stopped getting a good reading on our in dash depth finder for our 1999 Bayliner Capri 1950. We don't know how to reset or callibrate it (know paperwork). Below the dash, there we are several rocker switches ... ACC, Depth, Blower. We don't know how to use the depth rocker to reset. When boating we get crazy readings that range from -18 to 397 in the distance of moving 10 feet. It worked last year. Sometimes we get a -- reading, other times numbers like above, and a few times CAL. One site said to check to see if the transducer is OK ... but where is this?
Editor925
  • 285 Answers
SOURCE: My Lowrance X-51 is not reading the depth sitting
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Posted on Aug 01, 2009
SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Posted on Aug 18, 2009
juandiablo
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Posted on Sep 19, 2009
TechnoMarine
  • 132 Answers
SOURCE: My furuno depth finder gives me crazy depth
Turbulence on the transducer is almost certain. If transom mounted, **** it slightly deeper aft and ensure that the leading edge is not exposed. If through hull, call me 847-746-0100
Posted on Jan 13, 2010
Editor925
  • 285 Answers
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Posted on Feb 02, 2010
What can i do to stop the flashing of the depth finder at times it will not show the current depth
Hey Joe,
Wow.. where to start.. there are so many things that will cause the issue you are describing.What type of electronics do you have? Does this happen at all speeds? Where is the transducer mounted? I need more info about when it stops reading.
1.Wrong setting on the unit
2 Bad transducer
3 Bad transducer mounting (either inside the hull or outside the hull.)
4. (In hull) Turbulence going under the boat (mine quits reading at about 55 mph @ half trim...the boat is lifting so much it causes air pockets so the transducer loses contact with the water)
5. (Outside hull) Turbulence around the bottom of the boat where the transducer meets the water.
Good luck,, when you get the info.. reply to me..
Jun 03, 2017 | Boating
Volvo penta wiring diagrams
Go to boat manufacturer and ask. However you might first check your ground connections at the motor and at the dash for corrosion or just loose.
Jul 14, 2014 | Health & Beauty
Lowrance Elite 4X fish finder that reads between 1.5' and 2.5'
Hey Anon
The transducer installation is more important than anything.. next to correct wiring! You must make sure the mounting is good,,, if its outside the hull, make sure its sitting 1/16th below the hull with no obstructions.. if its inside the hull, the medium you used to fix the puck to the hull must be porosity free and the puck sitting as level with the WATER as possible..
Now, take the manual to the lake with you and DO NOTHING but read the manual and apply what you read to the unit,,, read -repeat - read-repeat.. forget about fishing... now read-repeat and learn... IF nothing seems to be reading correctly.. its probably the transducer installation.. YOU DID use a/the transducer specifically for this unit!!
Jun 24, 2017 | Lowrance Elite-4x Fishfinder
Jan 21, 2010 | Humminbird Boating
Lowrance depth finder missing adapter cable
Jul 28, 2009 | Boating
Jul 07, 2009 | Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would...
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Jul 03, 2009 | Lowrance Boating
Problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Jan 07, 2009 | Navman Fish 4150sx GPS Receiver
Boating Logo
763 people viewed this question
Top Standard Horizon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
