Question about IBM Deskstar 75GXP 61.4 GB ATA-100 Hard Drive
How to restore data files from a dying hard drive?
I was installing a dying hard drive to my system as slave hard drive. It was successful and the window XP started normally. I went to my computer and found the dying hard drive was assigned drive F and G probably due to the previous partition made. After accessing few data files, my system hanged and the window could not be boot up. I detached the dying hard drive and window could then boot up.
Now I wish to restore all data files from the dying hard drive.
  • Dominic Ching May 23, 2009
    Yes, I have Window installed in the dying hard drive.
  •  Arther Scott
    Arther Scott May 11, 2010
    You may want to check Cnet for a free program to recover data from your drive. That being said, did you have Windows installed on this drive? This may cause a conflict when trying to access data on the drive, it may be trying to load the windows from that drive.
  • 531 Answers
You'll need any of this.
I used SnapShot before. Very easy.
Posted on May 23, 2009
Atheros pcie ethernet controller v2.0.2.0
The boot sequence of the laptop runs through all the options that are set as available in the Bios. The fact it is pointing to the PXE Rom means that it cannot find an operating system on the laptop on the hard drive. Your system restore has failed, possibly because some files have been badly corrupted, potentially the sys.ini file. I'd hazard a guess that this was due to a virus, or similar.
Did you perchance accidentally install something like "antivirus 360" or "windows 2012 antivirus"? These are known malware programmes.
As a solution, your safest bet is to perform a repair install using an OS disc and REPAIR the Windows installation when prompted. If that fails, you should then reinstall windows, which may mean you will lose your data (one way to recover your data prior to this drastic measure, is to remove the hard drive and set it as a slave to another computer and pull off the data, or use a docking station to transfer your files). IF you succeed with the repair as described above, delete the system backup files and run an antivirus to check you have no traces of a virus left. DRWEB can be downloaded from the internet to do this.
IF you have to reformat the drive, google for a freeware file recovery utility, and use this to search for any files that you may have lost in installing windows.
As an alternative, to rescue files, obtain a live Linux CD, which will run from your CD drive and this will allow you access to the files on your hard drive, which you can then recover via a USB flash drive or similar
Jul 13, 2012 | Dell Computers & Internet
Hard drive ST3160021A, error code HD521-2W
If this error is coming from the PC Doctor or When the OS (WindowsXP, if it is) then the chances are that your hard drive is failing. Back up your data immediately and replace the hard drive. Remove the HDD and connect it as a slave into another system and copy the data. Cheers - Parveen
Feb 04, 2008 | HP Compaq Presario SR1720NX (EL435AA) PC...
Hard drive does not recognize a file system
Buy a software called EASUS DATA RECOVERY WIZARD, install it on a working computer. Connect your hard drive as a slave and open the program. Use the Complete Recovery Method to recover all your files. It is usually pointless to try and recover system files. Unless you want to recover your documents and files that were there in the hard drive.
Apr 03, 2012 | Iomega Computers & Internet
I loaded data from another computer that must have had a virus and now my new toshiba satellite L655-S5153 computer boots up to a blank screen, even in safe mode. the computer didn't come with...
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Jul 16, 2011 | Toshiba Satellite L655-S5153 Laptop
Oo.comhi. if i delete my files from SDR-H85 PANASONIC how i will recover back without problem. i did with one program but didnt help.
http://majorgeeks.com/FreeUndelete_d4407.html
FreeUndelete restores deleted files, including those removed from Windows Recycle Bin. In case of accidental removal of files on a NTFS (1.0 and 2.0) (default for Windows Vista , XP, 2000 and NT), FAT32, FAT16 or FAT12 file systems this is the utility to help.
Supported file systems:
NTFS 1.0, NTFS 2.0, FAT12, FAT16 and FAT32
The recovered files are saved into a new user-selected location to prevent overwriting the deleted files on the original media. hope this helps
Apr 10, 2011 | Panasonic SDR-H85 Silver 80GB Hard Disk...
Ps3 says hard file disk corrupted and has to be restored but it just keeps doing this and has restored like 15 times and has not fixed itself. what can i do
1. Restore File System
Enter Safe Mode and select "Restore File System". "Restore File System" will attempt to repair damaged files on the hard drive. If this does not work, try the next step.
2. Rebuild Database
Enter Safe Mode and select "Rebuild Data Base". "Rebuild Data Base" will erase messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. Then attempt to rebuild the PlayStation 3 database. The content that is erased will not be recoverable. If this doesn't work, try the next step.
3. Restore PS3 System
Please note this will erase all content on the hard drive and will not be recoverable.
Enter Safe Mode and select "Restore PS3 System". "Restore PS3 System" will restore the default settings and will format the hard drive. If this doesn't work, try the next step.
4. Re-seat the hard drive
If you have replaced the hard drive in the PlayStation 3, make sure it was installed properly. If the hard drive is not seated correctly, it may cause problems.
5. Try another hard drive (if possible)
There may be an issue with the hard drive that is installed. Try replacing the hard drive with another one.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
My asus X80L laptop operating system has failed to log on or cannot be loaded. Is this mean that the operating system has been damaged or actually the hdd itself?
Probably the OS, try a safe mode boot or a restore install ( won't lose files), if that fails, then a full restore may be called for (will lose all files). Or you can pull the hard drive out, slave it to another computer with sata, test it and see if the drive is working and pull off all your data, back it up and reinstall and do a full install.
Jan 27, 2011 | ASUS Computers & Internet
C:\Windows\Panter\unattend.xml file is corrupted
Why are you worried about this? You are getting a warning that the hard drive is about to die. In your place, I would copy any data I wanted to keep to the desktop and then replace the hard drive.
You can then image the original drive to the new one and try the restore again.
The Panther\unattend.xml file is created and Windows uses it during the restore process in order to know what to do, copying it from another computer (if you can find one) would probably totally mess up the installation. The reason it cannot be parsed is probably because it was created on a section of the hard drive that has already failed - remember, your hard drive is dying.
Mar 05, 2017 | Compaq Presario 700 470024-192 Notebook
If I do a windows complete PC restore,will i lose all my saved files?
If you do a System Restore using Windows own program you will retain all of your files
If you do a repair via the Windows disk you will save your files
If you do a full re-install using the Windows disk all bets are off
It is safer to back up onto memory pen or DVD all of the files which matter to you and then do the re-install , you will need a bootable copy of the Windows disk and a copy of the disk containing the drivers for the Motherboard etc
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Seagate external hard drive
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your Seagate external.
Oct 24, 2008 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
IBM Deskstar 75GXP 61.4 GB ATA-100 Hard Drive Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
