Question about Zyxel NBG-415N Router
NAT port map UPNP device not found
I have Windows Vista desktop & Laptop routing through a Belkin wireless (model#F5D7230-4). I use BitComet to download movies. Both listening ports TCP & Udp are open & my WAN light is green but my NAT port map failed (UPNP device not found) so my download speed is slower than it could be. I'm new to the world of PC and have already dealt with 2 defective Dlinks which is why I now have a Belkin. I'm extremely frustrated with this problem and obviously I don't stand alone with it. Any and all help with this problem would be thankfully appreciated!!!!
  • 67 Answers
SOURCE: how do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
Posted on Mar 31, 2009
SOURCE: Can't connect to XBOX Live because of Strict Nat settings Netgear router WGR614
I tried to find this "Access Point Mode" on the WBR 1310 as suggested above and I couldn't. I spent hours on the phone with support from Xbox, D link, and my ISP Bell Sympatico's technical support trying to get my Strict NAT to Open. I finally got everything working and if you follow the instructions below in order, you will too. Here's what you should know if you have the D Link WBR 1310 and Bell Sympatico Internet.
1. Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your timezone. On step 3 this is important, select PPPOE setting. On the 4th step leave the Address Mode in Dynamic and enter the Username and password supplied to you by Sympatico.
Once you have configured your Router to work with the PPPOE settings that Bell uses (Most DSL providers use this setting) you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/Xbox_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mensioned on this page is for each port you forward under the box that says "IP Address" do not put the IP address of your computer. You put in the new IP address of the Xbox 360 which was one of the 5 that was generated on the previous link. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start, run, type in cmd then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Also after reading several forums you don't need to enable DMZ host and leave the UPnP enabled. By default they are set this way anyway. Hope that helps.
Posted on Jan 05, 2008
Tech 75
  • 85 Answers
SOURCE: Problem with my Belkin wireless (model #F5d7230-4) resolved.
What is your current download speed? And what is your service contract speed you are suppose to be getting.
And yes they can cap your connection speed.
Posted on May 24, 2009
  • 93 Answers
SOURCE: Bitcomet and Belkin router
To fix this issue all you have to do is,You should open the bitcomet downloader portnumbers on the belkin router,you need to open default page by typing 192.168.2.1 in address bar.
And also i would like suggest you to disable firewall on router and check for firmware update... It may be quiet difficult for you to do all this.please call tollfree number"belkin" and ask them to change these settings which i have mentioned.and it will definitely work.....
.....Hope this is help full for you
Posted on May 31, 2009
  • 10406 Answers
SOURCE: nat port mapping and UPNP problem
The D-Link router is blocking all "unsolicited" network traffic trying to reach any of the computers on your "home-network".
Compare it to having your receptionist receiving all the calls from telemarketers, and _not_ letting any get through to you.
You have to tell the receptionist (or configure the router) to identify which telephone-calls (or peer-to-peer file-sharing requests) are to be allowed to be routed to a specific telephone (or computer) in your "home-office".
This has *NOTHING* to do with "UPNP".
Posted on Sep 13, 2009
I want to change me NAT to open
there is nothing like changing the NAT , but yes you will get rid of this message on you PS3 or XBOX once you open the ports on you belkin router .
* TCP 80
* UDP 88
* UDP 3074
* TCP 3074
* UDP 53
* TCP 53
turn off the firewall , enable upnp and assing a static ip address on your gaming device
Oct 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Listen Port of TCP: 2869 (Blocked by Firewall/Router) how do i change nat router settings?im blocked when usin bitcomet software
try to disable ur firewall setting, enable nat, and rip
try set port forwarding to port 65535, dont forget to set bitcomet port 65535 too
Oct 08, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Nat port mapping and UPNP problem
Sep 13, 2009 | Zyxel NBG-415N Router
The connection works but the unit is nowhere to be found
Belkin may have a firmware upgrade available that may help.
Do you have UPNP installed (windows xp/vista) in the network components and this is usually required to see any UPNP devices on your network.
can you access the device from its default IP ?
In your browser, type “192.168.2.1” then press "Enter"
Aug 07, 2009 | Belkin (F5D7230-4) Router (587009)
Firewall and NAT router configuration/Router problem????
set a port forwarding on your router.
the port you open on port forwarding is the port you are going to use on your bitcommet
Mar 23, 2009 | Computers & Internet
How to change NAT type on sierra wireless 595u aircard?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Feb 15, 2009 | Belkin N1 Vision Wireless-N Wireless...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Online and downloading is very slow
Go into your router settings by opening your internet browser, clicking in the URL address bar, and typing in the router's domain address, either 192.168.0.1, or 192.168.1.1 or 192.168.2.1, and Enable UPnP.
This is known as port forwarding.
Good Luck
Chris (ziraffa)
Jul 06, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Zyxel NBG-415N Router Logo
2,622 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
