Question about IBM ThinkPad T60 Notebook
Bios password ibm "T60"
I forget the password for the laptop
how can i reset or delet it?
thank u
  • 118 Answers
BIOS Password solutions here
Posted on May 23, 2009
My laptop IBM Lenovo Thinkpad T60 of type:2008-AD7, S/N L3-C0670 06/07, seems to be locked at the very start when the power is turned on, it shows a lock and enquires a password from the early start. it...
There is no default password on the T60.
If you are seeing a lock symbol then somebody has set the supervisor password. If you can't guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T60 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 05, 2011 | IBM Lenovo ThinkPad T60
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    I have ibm think pad T60 and i forget my bios password how can i reset my password ?
    To reset the BIOS read the information from this link.
    In case of your IBM ThinkPad laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
    Dec 27, 2010 | IBM ThinkPad T60 Notebook
    I have i problem with my lenovo thinkpad t60, how do i remove the bios password in it?
    To reset the BIOS password read the information from this link.
    In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
    Nov 09, 2010 | IBM Lenovo ThinkPad T60
    Startup password can't get into bois ibm t60 laptop tryed removing both battery and nothing i can't get it to do nothing
    From your hardware maintenance manual:
    Supervisor password: A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
    Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
    Aug 03, 2010 | IBM ThinkPad T60 Notebook
    I forgot my power-on password for my ibm thinkpad t60 and i can no longer use it. is there a way to remove the password so i could use the laptop?
    take it apart and remove the bios battery on the motherboard,remove main battery,set something heavy on power button to hold it down and wait,maybe a day ,or a couple hours ,it varies ,sometimes doesnt even work,but this one should reset,reassemble and power up ,good luck ,hope this helps.aloha from maui todd0708
    Oct 22, 2009 | IBM ThinkPad T60 Notebook
    Thinkpad T60 ... BIOS + Power Password
    Instructions for resetting the T60's passwords can be found in the Hardware Maintenance Manual, which can be downloaded from Lenovo's website at http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-62733
    Apr 01, 2008 | IBM ThinkPad T60 Notebook
    PROBLEM WITH T60 IBM THINKPAD
    If your laptop received a password protection and that password was forgotten there is no user manageble way to recover or disable the password. Maybe the person who tampered with it tried to reset the BIOS by removing the battery or things like that. They woun't work as the password is stored in a NAND ROM memory section of the BIOS, meaning that it isn't volatile and can't be erased like PC's BIOS by removing the power and battery. If you can't modify BIOS settings or you can't get rid of the "locked" display image, you need to go to a service center to have the password removed by them. This operation requires BIOS flashing and can't be done by the normal user as it involves specialised hardware. Sorry for I can't assist you further with a easy fix or something like that.
    Mar 11, 2007 | IBM ThinkPad T60 Notebook
    IBM ThinkPad T60 Notebook Logo
    1,275 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
