Question about HP Officejet 5610 All-In-One InkJet Printer
HP Office Jet J6480
I am getting an error on my printer that says No Connection
    Scholar:
  • 191 Answers
HI,
Follow the steps to refrsh the USB connection which will resolve your problem.
=== Refresh USB Devices ===
1. Right-click My Computer icon on the desktop, and then select
Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click 'OK' to confirm the removal of the device.
NOTE: Repeat steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the
computer restarts, a "Windows has detected new or added hardware" message window will open.
Posted on May 23, 2009
What does error Code E000732-0001 on a Canon irc 3220 error code mean?
Hi Bob Smith,
Error Code E000732-0001 is a reader board error. Please check all your connection on your printer if there is a unplug connection connected to a device. Or just unplug and plug all the connection on your printer.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Xerox WorkCentre PE16 All-In-One Laser...
Error code 360
Have you tried re installing the printer driver, or searching the printer website for an updated driver
May 01, 2014 | Canon Pixma MX360 Printer
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Printer won't print
Troubles with the connection or power supply could be another issue causing failure to print in your printer. If there is any loose connection or error in the cables or connection, your printer might fail to work at all. The problem might be easily averted if you are checking the connection and ensuring that all the connection are intact. You might disconnect the cables and reconnect them, to ensure that they are intact.get more help and information for printer repair hope this helps you.
Thanks
Michel
Feb 21, 2011 | Lexmark E240 Laser Printer
Command error on epson 9600
Are you sure it is a 'command error' and not a 'communication error'. I could not find anything on a 'command error' but did find this on a 'communication error'.
Q: Why am I getting a communication error when I try to print?
A: Check the following if you are getting a communication error when printing:
Make sure the type of driver you installed matches the ink type in the printer. Verify the ink type by checking the part number on the ink cartridges.
Make sure the printer interface setting matches the connection type you're using. By default, the printer interface should be set to Auto, which supports all connection types.
Check the physical cable connection and make sure the cable is not be longer than 10 ft. You may want to replace the cable.
You may also get communication errors if the printer name is not set correctly. Contact EPSON at (888) 377-6611 or (562) 276-1305 to get instructions on how to verify this.
You might want to check to see if you have the current drivers for your printer and operating system; a new driver can be downloaded here.
Trust this is helpful.
Dec 14, 2010 | Epson Stylus Pro 9600 InkJet Printer
I keep getting ''Printer connection failed'' message
It is seen that if there are any issues with the printer drivers, issues like connection failure may occur. There are chances of drivers being outdated and corrupt. In such situations, you have to update the drivers. If there is any yellow exclamation mark next to printer driver, You need to replace that corrupted driver with the correct one. Before the installation, you also need to check for compatibility. Sometimes, incompatibility would cause issues like printer connection failed, etc.
Get more information and help to fix Printer Connection Failed . Hope this information helps you.
Jan 28, 2010 | HP PSC 1315 All-in-One Printer...
Communication error
Remove and rthen reistallthe printer driver from you PC and select the USB connection option.
Sep 24, 2009 | Epson AcuLaser C900 Printer
Uknown device Error - Canon PIXMA M180 All-In-One
well i'm not sure but did u try to change the usb connection itself? or if it doesnt work try to chek if there are any windows errrors but most propably the connection
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Problem installing epson stylus color 450
Electronic equipment usually go bad if not used, at the prices of today's printers an scanners, i am sure you can get a good deal (maybe a combo printer with scanner)... go for it!
May 04, 2008 | Epson Stylus Color 480SX InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
500 people viewed this question
Seeker5211
Seeker5211
