Question about HP Compaq 6715b Notebook PC
Laptop not restarting up
Ok my campaq 6715b keeps looking like it will start up but when it gets to the point when it says windows xp, it starts going through the same thing over and over again and never quits..... what should i do? it is from my cyber school.
  • 464 Answers
Your ram should be the problem from starting your device..  if you can do this, you can remove the ram from the device , clean it with an eraser and then reinstall it,,that should work.but if your laptop is under warranty still give it to the nearest service centre
Posted on May 23, 2009
Ok here is what is going on on this unit and the 2nd time. Nothing to do with memory. The MB and power connector fail on the MB due to lousy connection which then caused component failure in the regulator on the MB. The unit fails to power up and stay charge. We had to have the MB replaced in May and it is happening again. These units are lousy products. Never has this ever happened with my Dells. This is the 4th and last unit I'll ever by from HP/Compaq.
Posted on Sep 08, 2009
How to reset my computer to an earlier date
If you are talking about in the Windows operating system all you have to do is move you cursor down to your task bar and all the way to the left. Right click on the time, and select "adjust date and time". Then type in or select your desired date and time and press okay. You can only change your time if you want, after that you are done.
Mar 01, 2011 | Toshiba Computers & Internet
Ok my Sony vaio Model #VGN-NR120E keeps restarting on windows error recovery. I try starting in save mode,safe mode with networking, save mode with command prompt, last known good configuration...
HI dmanhd97,
Try this, restart your pc then press f8 continuously, this will take you to safe mode. then after that go to start>run> type in msconfig (windows xp) , and start>search> type in msconfig (windows 7)
this will open up the system configuration under the general tab
select the diagnostic start up then apply>ok>restart
Hope this helps,
thx
banaple
Sep 02, 2010 | Sony VAIO VGN-NR120E/S Notebook
When cp is bootin up, it goes to welcome screen an then is black screen, stays black except the mouse arrow is showin' it bwon't boot up no further,can sombody please help, Jack
Restart the Notebook and keep tapping the F8 key to access the Windows advanced options.
select Safemode.
Once you are in safemode, follow the below steps :
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
Mar 14, 2010 | Compaq Presario 700 470024-192 Notebook
HP6715b hangs on start-up when docked
Try without connecting any devices.
Try to disconnect the dock.
Try to boot in safe mode.
Sep 11, 2009 | HP Compaq 6715b Notebook PC
Look for windows recovery CD for AcerAspire 5610
It is good when you can start Safe mode it can help.
What realy happen when you start in 'Normal' mode ?
Do the following:
Start the computer in Safe mode.
Open My computer, than Right-click on Disk C and click on properties.
Click on Tools Tab and then click on 'Check Now', and then Start (leave two options above unchecked)
When it finishes, it should show that Disc check is complete, close it.
Right-click on My Computer, click on properties, and then Advanced Tab.
Click Settings in Startap and Recovery field.
Uncheck Automatically restart and then OK.
Now restart and see if it will bring Windows in 'Normal' mode.
Are there Errors, Blue Screen . . . . ?
If so, try one more thing.
Go to Windows start options (the one you go to select Safe mode) and go to
Last good known configuration
and pres Enter and once again, Enter.
Did you get to 'Normal' Windows ?
Mar 27, 2009 | Acer Aspire 5610-4648 Notebook
Averatec laptop running Windows XP keeps restarting itself
A couple of suggestions...
First off you might have a hadware getting ready to fail. Follow this link it might be helpful
http://www.computerhope.com/issues/ch001088.htm
Second, it might be you have a virus. If so try booting into safe mode run cntrl+alt+del and look for files in caps (especially LSASS.exe and WINLOGON.exe) if these files are corrupted then you might want to start backing up your data and reinstalling the OS. Otherwise run a virus scanner like xoftspy to check for viruses.
Lastly in XP, for system restore to work you needed to make periodical check points so it is correct if the last restore point was August 2008.
The only other thing I can think of is going into bios and seeing if the computer reboots itself. This would probably eliminate any virus and point out a harware failure.
Feb 25, 2009 | HP Officejet 4215 All-in-One Color Photo...
Compac presario mouse stuck when on desktop but not on log in screen. little box on task bar with red through box
Get an external usb mouse, once you have it plugged in restart the computer. Then go into the device manager and uninstall your old mouse, unplug the usb mouse, then restart. That should fix your problem. Let me know if you need more details.
Feb 19, 2009 | Acer Aspire 3680 Laptop
Need to restore computer **** dont have a cd is there any other way
Follow below instructions......
To use System Restore to restore Windows XP to a previous state, follow these steps:
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
thank you.......
Jan 22, 2009 | Toshiba Satellite A135-S4427 Notebook
Missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
Dec 16, 2008 | Dell Inspiron 1501 Notebook
I have no sound in my computer
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page, click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK
If still not go get the sound driver reinstalled
Hope this will help
thanks
Kevin
Sep 16, 2008 | Computers & Internet
HP Compaq 6715b Notebook PC Logo
214 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
