Stiff screen on laptop
The screen is so stiff (hinge) that it is very difficult to open and the stress of levering it to a fully open has caused a crack in the plastic back cover.  Can the hinges be lubricated? With what?
  • 1 more comment
  • flyingdancer Nov 26, 2007
    further to durrydurry's problem, report mine has now broken at that point and the hinge plate has separated from the lid. Do you think that a computer repair shop would be able to do anything to fix this, or should I try the "superglue"?
  • dabdil Nov 28, 2007
    Hi
    I intially had a similar problem with my ibm thinkpad t20 the hinges were very tight and with the constant open and closing on a daily basis finally cracked the top bezel which is part of the frame for the keyboard and the dvdrom drive. Also it was broken from inside that was holding the dvdrom drive cage together. It wasn't until I dropped it one day when I slipped on the stairs and the laptop fell apart I managed to get to the nuts that were too tight and loosened them and had to glue everything back together it works fine now and its no longer a challenge when open and closing the lid.
  • Anonymous Feb 24, 2008
    I have a Gateway MX6448 with the same problem. I took a old printer refill
    syringe and some 3 in one oil and placed 1 tiny tiny drop on each side of both hinges. This worked for me but be careful not to use too much.
    Problem Solver:
  • 6 Answers
Can you please tell me what is the notebook model
you should not lubricate the hinges
Posted on Oct 20, 2007
Stiff hinge..I try and it work!!..Take out the hinge from your laptop.. put the hinge area into the flame (gas cooker at your kitchen). put it for 3 or 4 minutes. Immidiately soak it into cold water. It will loose a bit. if neccessary, repeat the process until you satisfied.
Posted on Jan 22, 2009
Grand vitara 5 speed manual stiff to change when warm
what is stiff (add a noun here)
blush.....
clutch pedal stiff
shifter lever stiff.
grinds , a bad clutch will make the lever seem stiff or will grind, if forced.
gears balk? same as stiff.
false neutrals. (slips , gear not engaging)
Nov 07, 2016 | Suzuki Grand Vitara Cars & Trucks
Hinge stiff on hp model g70
If you remove the bezel around the screen, it is possible to adjust the tension.
You may find the tutorial useful.
HP PAVILION G7 take apart video disassemble how to open disassembly
Feb 03, 2014 | HP G70-250us Notebook
Honda crf 100
You possibly have corrosion or contamination built up in the lever pivot point. Disconnect the cable and try lever - if it is stiff or difficult to move, you'll need to take the handle off, clean pivot and contact points with a SOFT wire brush ( brass brush recommended) lube it with white lithium grease and re-install. check for freedom of movement before re-installing cable. If it moves ok but cable is stiff, you'll want to next lube the cable with a liquid spray lube - sometimes the new cables are not properly lubed!!
Apr 27, 2013 | Motorcycles
1995 Chevy suburban back door hinges too stiff
Lubricate the hinge or the hinge will have to be replaced.. I recommend wd40 first, then a finger tip amount of grease on top of hinge pin. the oil from the grease will keep the hinge constantly lubricated. It's not too late.
May 22, 2009 | 1995 Chevrolet Suburban
Door very stiff won't close tight
I have the same problem with the side doors of my 04 express. I put penetrating oil on the hinge pin with a hypodermic needle (hard to find). It is important that the oil gets into the hinge. I bent one set of hinges and broke a hinge because I waited too long to oil the hinge. The door may not close correctly because the hinge may be slightly bent. Keep all other hinges well lubed especially during the winter months when the hinges can be exposed to road salt. Fixing a bent hinge is difficult at best.
Aug 28, 2008 | 2004 Chevrolet Express
Viking Ultraline Professional Gas stove
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
Jan 01, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Stiff hinge pin
These systems use a pretty generic hinge set-up. These can be dealt with in two ways, one involving a safer method for future adjustments. The hinges are two separate bars on each side of the monitor with friction cuffs that use the tension between their two pieces to hold the monitor stiff. Generally my experience with Acer models is that they ALL ship with pretty stiff hinges, which is a double-edged blade. Stock hinges that don't click when fresh have a tendency to need replacing after a couple years, where as my acer TM4K hinges are still strong today after 4. The best way to loosen these babies up is to just use it. About an average of 75 open/close cycles break in the hinge to where it stays nice & tight, but stops clicking or cracking. The other way, which is for those who are afraid the LCD housing will crack it's so tight, is to take the monitor off, but not apart, carefully using two pairs of needle-nose pliers, hold steady the monitor end with one set and with the other, flex the flat end of the now loose hinge back and forth as far as you can get it to move until you feel it is to the right strength.
It helps to mention that too little is better than too much, as I see a good amount of people burnt out with their Compaq Evo & Presario (ca.2001-2) hinges, falling to the ground soon as you let it go, only 6 months after their last replacement set.
Nov 06, 2007 | Acer TravelMate 2300 Notebook
Screen problem
Had the same problem/same symptoms, just after it started to get stiff in the hinge and make the sound of wires being "crinkled." When I inspected it closely, I could see that the left hinge has excessive play, i.e., it's loose. I expect to remove the screen and find that the hinge/connector assembly went bad, put stress on some of the wires (or allowed enough play for a connector to lose firm contact), and killed the video. I replaced mine, used Motorola Mobile Phone Tools software to pull off all the data, and let it be. Best of luck.
Jun 28, 2007 | Motorola Mobility V710
Computers & Internet Logo
1,277 people viewed this question
Alun Cox
David Payne
David Payne
