Question about HP DesignJet 500 InkJet Printer
Hp designjet 500 printer - system error 2110
First got an out of memory to spool in my software ap corel's painter x. then later came back to printer reading 'ready' - tried to change setting from role paper to sheet but got this message
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Corrective Action: Try the following:
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 4000 plotter error01.0.10
Try the following: Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer. if the issue persists replace the Gamut PCI PCA If the System Error continues, replace the Main PCA.
venkateshwar, hyd, A.P,India.
Sep 16, 2011 | HP Designjet 4000ps InkJet Printer
Hp designjet 800 ps plus system error severe errora: 0x8010003 task: tmech file: sequence.c line: 636
Notate the error and put it in a search. Since it appears to be a server error, remove then reinstall the driver software.
Jul 09, 2011 | HP DesignJet 500 InkJet Printer
Hp designjet 5500 system error 0b0004 00000012
Hi...Pls check the cable from iss to supply st is correctoly connected.
APS may be faulty,check replacing the APS if error continues then the problem in main pca replace them .
your problem may be resolved 100% .
Aug 27, 2010 | HP DesignJet 5500PS InkJet Printer
HP Designjet 500 24-in Roll Printer error message 2110
Service Station failure. The possible cause could be:
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
The Aerosol Fan has reached its maximum current limit.
The Service Station motor has shutdown because of blockage.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
My ploter is ready mode when printing giving error 0a0010-00000001 system error and not working model hp designjet 1050c pl resolve my issue
System Error: 0A0010
Problem
Description:
Problem in Pressurizing the Air System.
n Replace ONE Ink Cartridge at a time, checking if the error code
disappears.
n Check all the cables of the APS and make sure they are correctly
connected and are NOT damaged.
n Check all the tubes of the APS and Tubes System and make sure
they are correctly connected and are NOT pinched or damaged.
n Faulty APS Sensor, APS Valve or APS Pump. Replace the
complete APS þ
WARNING Only replace one component at a time and check if the error has
gone before replacing another component. Using this procedure
you will be able to determine exactly which component failed
Oct 29, 2009 | HP DesignJet 1050c InkJet Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
HP designjet 500 - system error 2110
Hi urlink:
This is your problem:
System Error: 21:10
Problem
Description:
1. The steps counted by the Service Station motor are not consistent
2. The Aerosol Fan has reached its maximum current limit.
3. The Service Station motor has shutdown because of blockage.
8-52 HP DesignJets 500 and 800 Series Printers Service Manual
Service Station and Aerosol Fan
Removal
NOTE Refer to the table on Page 8-4 for information on screw types.
1.
Perform the Service Utility "Unlock
Carriage" - Refer to Page 4-22.
NOTE Switch off the Printer after
performing this Utility.
2.
Remove the Right Hand Cover - Refer
to Page 8-7.
3. Manually move the Carriage out of
the Service Station.
4. Disconnect the Service Station and
Aerosol Fan Cables (connectors P5
and P9) from the Interconnect PCA.
You will need an HP certified technician to service this product.
Hope this helps
May 23, 2009 | HP PRINTER,DESIGNJET 500 42'' InkJet
HP DesignJet 500 InkJet Printer Logo
674 people viewed this question
Seeker5211
Seeker5211
