Question about Shuttle SK41G Barebone
Computer wont urn on
I turned on my computer one day and olny two leds came on on the mother bord no fans or disply
I want to my bioes reset.how?
take off the battery and turn on computer then turn off , back the battery to its place again and turn your computer on , it will be reset
if you see that is helpful please don't forget to vote me
best regards
Apr 25, 2011 | Intel D945GCLF Motherboard
How to find power shlots & etc for mecury PMNCP73V mother bord
Here is a picture for reference
SYSFAN1 is the case fan power supply ATX1 is the plug in for your power supply in the case PJ1 is another power supply plug SW1 is the assorted jumpers to power on and off computer from the case as well as the LED ligts present
Apr 13, 2011 | Mercury P4VM800M7 Motherboard
Installed Crosshair MB in new case. Motherboard LED lights come on but CPU and fan do not light up or turn on. Tried dif power supplies and cases, no luck.
Make sure that the motherboard LED switch on the back panel is set to off and if want to turn it on go into bios and set it. If it is active thru switch and not thru motherboard bios it will not allow you to turn on PC cause it is in maintenance mode.
Oct 26, 2009 | ASUS CROSSHAIR Motherboard
I have asuse a8ne mother bord..fan not working
Dear Sir Change the FAN power Cable Related Problem but your have no idea about the cable just send me a fan we are Repair for this Fan Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok.
Email:support@compudesk.in
Web: www.compudesk.in
Jul 13, 2009 | Computers & Internet
I have problems with my lan party 400a mother bord
Well everything doesn't work or it would post. I'd check the manual for the light code,it will point you to the problem. Other option is to contact thier support at the site.
Jul 12, 2009 | DFI LANPARTY NFII ULTRA (LANPARTY NF2...
Gateway GT4010 will not start most of the time the fan just runs.
Oopen cpu cabinet and then check wehn u power give to it led on mother bord is flashing or not?
If flasshing then your motherbord get power.
Then reattch all connection to mother bord.
Pull cmos cell for 15 minutes from mother bord also change cmos cell if it has low volt or it is old.
Then also cg\heckl your smps box is working properly.
Jun 23, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Fans work but pc wont power up
refix ram and reattch all connection to mother bord.
ASlo remove cmos cell for 15 minutes from mother bord
also check smps is working fine
Apr 21, 2009 | E-Machines eMachines Desktop PC
D845GVFN disply problem
You check your VGA adapter, if it is buit in to main board, fixed cable connection, if it is add card remove and check the if is ok. if your remove then switch the board beeping twice faster beeps than the memory. Please response if this not solve the problem.
Jan 10, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Shuttle SK41G Barebone Logo
51 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
