Question about Bosch Dishwashers
Dishwasher not working after circuit breaker turned off
Dishwasher stopped working. No problems prior to this problem. No lights come on in the control panel. Using a multimeter I've proved that power is getting to the switch on the door, and from there to the circuit board. But no lights come on below the buttons on the door. Looks likely to be the circuit board?!!?? What tests can I perform to test the board? Thanks
    Master:
  • 595 Answers
Circuit breaker tripped because of fault in dishwasher, which is why it no longer works. Sorry but I can not tell you what dish washer fault is.
Posted on Sep 13, 2017
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Power to dishwasher and will not run
Check your thermal fuse. It will be inside the control panel, clipped to the control board somewhere. It's usually a white plastic square piece with two wires connected to it. The fuse should read a short. If the fuse is blown, you will need to replace it. If the fuse reads good, I would suspect you have a control board problem. Make sure you secure power to the dishwasher BEFORE you take any resistance checks, however. Even if the fuse is blown, you could still have live voltage on one side of the fuse. If you cannot find the fuse, there should be a tech sheet with wiring diagrams inside the lower kick plate below the door. This could be a tremendous help you as well. Let me know what you find.
Posted on Jul 14, 2007
  • 131 Answers
SOURCE: no lights on the control panel
check the thermal fuse at the control panel, the door switch, or the electronic control.
Posted on Mar 10, 2008
  • 7 Answers
SOURCE: GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Posted on Oct 16, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
  • 188 Answers
SOURCE: power to dishwasher but no power to panel
Open your console and check the continuity of the thermal fuse (clipped to the electronic control unit [ECU]).
Post your model number if you're still having problems and I'll try to assist you further.
Posted on Apr 04, 2009
Dishwasher stopped working. No problems prior to this problem. No lights come on in the control panel. Using a multimeter I've proved that power is getting to the switch on the door, and from there to...
Some Bosch models have a switch that stops the dishwasher from running when there is a leak. The water collects in the bottom of the machine. Give it a check.
Sep 12, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Lights flashing and dishwasher will not start
Take the kick plate off the bottom. It should tell you on a display on the bottom what is wrong. Resort to manual.
Jan 25, 2012 | Electrolux Dishwashers
Bosch classixx sgs43a52 dishwasher suddenly stopped working, no power lights. It's as if the power was switched off. could it be the switch?.
it could either be the switch or the power to the dishwasher has been turned off such as the circuit breaker
Oct 29, 2011 | Bosch 24 in. SGS43C12 Classixx...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer stopped mid-cycle, water in the bottom of the tub. Circuit breaker popped due to over-load. Reset breaker and it immediately popped again. Could this be cause by a jam in the grinder assembly?
My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
Jul 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
