Question about Toshiba P205-S6267 Notebook
The blue light comes on my webcam, the pic of it will come on but very dark then screen goes black, the settings on there will not help the lighting on the cam and the cam turns to black screen on it'
How to get my build in webcam uvc 1.7.115.0213 to work again? I have a Toshiba a205-4617, the cam will come on then it will go black.
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Blue screen then goes black but still has audion HELP !!!
when it goes dark can you pull up tv menu if not or ch number take a flash light and press menu on side of tv or remote and shine light on the screen, look really close and if can see any images such as letters or number then very possible have a defective lcd panel
Jan 17, 2011 | Vizio VO420E 42 in. LCD TV
WHEN i PUT MY WEBCAM ON , THE [ICTURE ON MY CAMERA THAT i SEE IS REALLY REALLY DARK , IS THERE A WAY TO LIGHTEN UP THE PIC SO THAT I can see it
Most webcams have settings for white balance and low light correction. I expect the low light setting might be what is causing your problem.
Some more webcam troubleshooting ideas might help.
Sep 21, 2009 | Microsoft LifeCam VX-1000 Webcam
Using Yahoo to chat - I plug in the webcam and attempt to broadcast but the screen comes up black ( no the cap is not on :))
You may have a problem with your internet connection. If your connection is too slow, it takes FOREVER for the webcam to get the picture to the screen. You may also want to check your settings for your webcam. If you have poor lighting (every webcam is different, but my webcam sees everything VERY dark), you will see a black screen. Set up a light behind you, and check your connection!
Sep 08, 2009 | Logitech Webcam
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Screen went dark
can you confirm make and model number please.
Dec 10, 2007 | Mitsubishi WS-55807 TV
Dark screen
did your blue light come on....if so will it go off when you turn it off? If not it could be your control box....
Dec 02, 2007 | Polaroid FLM-3734B 37 in. LCD HDTV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Toshiba P205-S6267 Notebook Logo
394 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
