Question about Refrigerators
Wont make ice
Sends water to the water dispenser, but doesnt send water to the ice maker. I just installed a new dual valve. still not working. could the clip be plugged in upside down? is it something up top in freezer not sending signal to the silanoid in the valve?
  • 1 more comment
  • sdkd1995 Oct 20, 2007
    Model FRT24XHA. turns out, after taking the unit completely out and removing the face plate, the female portion of part #16, where screw #24 goes thru cycle arm part #25, had broken off in the back plate(#16) inside. I replaced it with Gorilla Glue, let it dry and put it back together. seems to be working now. Now if I could get it to make ice faster, and get the water coming out dispenser to be colder, it would be the perfect fridge. Any ideas there?
  • watercarrier Nov 17, 2007
    KitchenAid Superba KSRS27QFBL00 - Manufactured in 11/97 ON, Canada
    It was in the house and it works fine, except that a couple months ago stopped produce ice. Water flows in the door dispenser and I have confirmed the tube to icemaker is not frozzed inside.
    If I fill in with water I have the ice after ~2hs. Instead of automatic, now it is manual!!! I have read some results about the valve in the bottom, but before start dismantle it I would like to know why it would work for the water in the front door and not for the icemaker?
  • Anonymous Jul 30, 2008
    put new smart pump on still no ice kennmore ellite side by side
  • 473 Answers
First, are you sure the ice maker is cycling and then no water?  If it cycles and no water check to see if the fill tube to the icemaker is frozen.  Also, what is the complete model # on the sticker inside the fridge?  Let me know so I can help.
Posted on Oct 19, 2007
SOURCE:
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
My side by side wont make ice and it usually makes a sound like water filling something but doesnt anymore should i replace the valve part that regulates water or the ice make part???
yes its indicating towards faulty water valve.
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Nov 01, 2011 | Refrigerators
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working on a samsung rf265aabp. water to selenoid no power to selenoid.
You won't have power to the solenoid till the ice maker dumps ice and sends signal requesting water. It only last for about 7 seconds.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | Refrigerators
Ice maker won't send water to unit. Solenoid is good
Make sure the fill tube where the water goes into the ice mold is not full of ice. Your old valve may have been leaking and it will freeze in the fill tube. Other than than maybe start the ice maker working by filling it with water and see if it dumps and refills.
You can swap the wires on the inlet valves and try the water dispenser. The water should go to the ice maker letting you know the valve works and the line is clear.
Aug 15, 2009 | Refrigerators
No water to ice maker but there is to the water dispenser in the door. Whirlpool model ED22PQ
This could be two reasons. The water control valve that sends water to the ice maker or the ice maker is not sending the signal to the water control valve to send water to ice maker There are 2 valves on back of your refrigerator one for ice and the other is for the dispenser. If ice maker is empty then the signal should be sent to back control valve and 120 volts should open the valve for about 4 seconds. If that valve is bad nothing will happen.You can test the ice maker by filling with tap water and if it cycles until time to refill and no water fills the tray then I think the water control valves need replaced. Click on link below and enter your model number in model search feature. Let me know what you find, Sea Breeze
http://servicepartstec.blogspot.com/
Water Valve - Dual Outlet
P/N: 2188542
May 25, 2009 | Whirlpool Refrigerators
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not getting water from water valve
CAN YOU HEAR THE WTR VALVE ACTIVATE OR TRY TO SEND WTR TO ICE MAKER HAVE YOU CHECK THE FILL TUBE INSIDE FREZZER WHEN THEY FREEZE INSIDE TUBE WTR WONT BE DISPENCE INTO MOLD
Nov 01, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
430 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
