When i type the *#2665# in KEYPAD. i accidentally press the #1 icon then after that i Confirm it. then and then. the Touch Screen dont work but the Hard Keys are working please help me :(
We can unlock your LG KU380 mobile phone with one easy code. just provide us with the network your LG KU380 is locked to and the LG KU380 IMEI (serial number) by typing *#06# into the keypad place your order and we can have your LG KU380 unlock codes returned to you with full support and instructions! good luck...If it's useful for you means plz rate me the 4 Thumbs ....
If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.................
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
the phone keypad is dirty, or the I C that control the keypad on the board of the phone is bad.
To check if the keypad is dirty, detach the front casing of the phone where the keypad is, clean with brush or a white cloth to clean of necessary dirt of the phone, then couple it back and test.
If after cleaning the keypad and is still not working, then the key pad I C on the phone board is damaged and it needs to be replaced.
Would advice if you to have the knowledge on how to open the phone, you can take it to a phone repairer to fix for you to prevent further damage on the phone.
my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
colin ?
