Question about Thermaltake Subzero4G Thermo-Electric Cooling for Socket A: A1617 CPU Cooling Kit
Can't find reset button (590 subzero)
Need to know how to reset Subzero 590
  • 71 Answers
IS LOCATED IN THE UPPER PART OF THE UNIT. remove the cover ( stain. panel wwod etc.) is on the left side red switch>>
Posted on Apr 02, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
No such thing as a reset button. There is an on/off behind the grill on the left, but it is a switch, it doesn't trip. If it is completely dead that switch could be bad or you could have a power supply issue such as a breaker or if it isn't a dedicated circuit and ther is a tripped ground fault on the same breaker.
Posted on Aug 05, 2009
Why does water dispenser light on subzero model 590 stay on?
It has different settings. Press the light button to change them.
Jun 21, 2014 | Sub-Zero 632 / S
I'm trying to find out if a 10 yr. old subzero 590 has a water filter built in somewhere ? if looked its seems like everywhere ? did they put water filters behind freezer panels.
This model didn't have a filter, you could have one installed in the water supply line under the unit behind the toe grill though. The next series after this model did have filters but this one didn't have a factory installed water filtration system.
Good Luck
Dec 11, 2013 | Sub-Zero 245
I replaced the water filter on my Subzero BI48SD and now the water dispenser does not work. Any suggestions?
After Replacing Filter, Press Filter Reset Button behind the Unit Grille for 5 Seconds to Reset Counters
Aug 12, 2013 | APW Wyott SubZero Refrigerator Freezer...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 590
Ignore the fan operation... That is perfect.
You are likely experiencing a DEFROST failure
(most commonly a defrost timer failure)...
part number 3081180 item 69 on your exploded
top view (top right side as viewed from the front).
There are typically only three (3) elements to a DEFROST
circuit:
- Defrost Timer (as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per YOUR DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
guaranteedparts.com http://www.guaranteedparts.com/picture_library/Subzero/Subzero-500%20Series/590.pdf
Sears
http://www.searspartsdirect.com/refrigerator-repair/symptom/REF0003.html
Carnac the Magnificent
Apr 06, 2017 | Sub-Zero 690 Side by Side Refrigerator
No water from water dispenser on subzero 590. ice does flow. anything to look for?
The most common is a clog in the water tubing or a stuck water valve solenoid.
Apr 17, 2010 | Refrigerators
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Subzero 590 shut off can't find reset button to turn back on fridge
There is no reset. There is an on/off but it doesn't trip. You should check the breakers at the breaker box and then call for service if the one for the refr isn't tripped
May 23, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Computers & Internet Logo
379 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
