Question about AudioBahn A8001DT Car Audio Amplifier
Display says lo
My audiobahn amp a8001dt display reads lo what is this
    President:
  • 1,348 Answers
It is set to low pass for frequency below 120hz,or you have low voltage to it.measure the power and make sure you have 12 volt
Posted on May 23, 2009
How can i get this amp out of protection mode?
You have a short circuit. I don`t know this particular piece of equipment but you should check all the output transistors/chips. Try disconnecting ALL the supplies to ALL the output devices and switch on, It should fire up, If it does, reconnect the positive AND negative supplies to one channel. If it still fires up, reconnect the next channel until you find the faulty channel then you could try doing comparison checks between the bad channel one of the good ones. These amps tend to use MOSFETS and are extremely intolerant to bad or loose connections. I hope this helps. You`ll probably find that you`ve got poor wiring, That will be your original fault. Ensure you make ALL connections good and sound before reconnecting the amp up with new devices in or you WILL be back at square one with no amp again. Ian
Jul 19, 2009 | AudioBahn A8001DT Car Audio Amplifier
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Audio bahn a 1800
If it has cooled down and still goes into protect mode, it likely has shorted output transistors. To eliminate other possible causes, read through the following page:
Oct 23, 2008 | AudioBahn A8001DT Car Audio Amplifier
Audiobahn A8002T
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Jul 23, 2008 | AudioBahn A8002T Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
My amp plys in burst
Make sure you have the correct speaker load.  Try one channel and one speaker (4 ohm single voice coil) at a time and see if there is one channel that is the problem.  See if it will stay on with no speakers attached.
Oct 24, 2007 | AudioBahn A8001DT Car Audio Amplifier
No sound from audiobahn a8002v amp
what readout are you talking about?have checked speakers yet?
Apr 29, 2007 | AudioBahn A8002V Car Audio Amplifier
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Dec 21, 2006 | AudioBahn A8000V 400W x 1 Car Amplifier...
AudioBahn A8001DT Car Audio Amplifier Logo
91 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
