Question about Fujitsu Siemens AMILO Pro V8010 Notebook
Keyboard problem my keys are mapping to other keys( when i press 'a' it is interpreted as a TAB key.as well as some of the keys are not working at all)
Maybe the problem...is clean he keyboard.. alwaizz~!!
Posted on May 23, 2009
Weres the comand key
If you use a non-Apple keyboard that includes a Windows key, the Altkey is the same thing as pressing Option, and the Windows key is the same thing as the Command key. You can change how these keys are interpreted from the Keyboard pane of System Preferences.
command key Google Search
Mar 15, 2015 | Computers & Internet
The character keys and numeral keys dont print only make a noice when pressed
From your query I interprete as they key is not displayed in the screen. First check with the external usb keyboard. If the external keyboard is also not working, please check the keyboard layout in the control panel regional settings. If the external keyboard is working well, change the laptop keyboard.
Nov 13, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
I got windows loaded but keyboard is locked. i can't type anything.
perform the following on the keyboard
  1. On the keyboard press the windows logo (image below)
  2. keep holding the windows key whiles you press the key U key in addition
  3. You should have a list of options.............choose on screen keyboard and with your mouse you can login and keep using your pc without a physical mouse.
Aug 04, 2011 | Compaq Computers & Internet
How does one access the @ in order to insert it into an email address when one sends an email? Pressing down SHIFT as I press the 2 key results in getting the " sign instead of the @ sign.
Hi, Solution 1: You can change the keyboard layot from the control panel Solution 2: Try the combination Shift+' button next to the Enter or try all the keys with Shift combination and find the @.
Mar 11, 2011 | Acer NSK8458AN Keyboard
Some of the keys of my lenovo G450 laptop are not working.what to do now?
Hello
What may have happened is that when you grabbed it, the pressure could have broken a trace (printed wire) on the printed circuit board in the keyboard. Usually the way a keyboard works is by making a matrix of switches where, for example, "a", "z", "q", "1", "`", and "tab" could be on one column and "z", "x", "c", etc are on one row. Pushing the "z" key makes a connection between the the corresponding row and column, and the keyboard's microcontroller interprets that as a keypress on the "z" key. If you've broken the connection to the "qaz" column, the microcontroller will never know that you've pressed one of those keys. Replacing the keyboard will give you a new microcontroller and circuit board, so you should be good to go!
Do rate the solution if helps
Good Luck
Dec 30, 2010 | Lenovo Computers & Internet
Sir, My keyboard is not properly working it's 1,esc,tab key is not working please sir solve my problem.
If the keyboard driver is not at fault, replacing it is the only sensible option since the replacement cost can be under $10 US and no one can repair them for that. Since it consistently affects a few keys, the integrated circuit that interprets the key-presses has likely failed.
Sep 06, 2010 | Computers & Internet
How do you set the time on the Logitech keyboard MX3200
Please do the following:
1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
2. Press (FN + F10). You are now in 'Set mode' - you can exit this at any time by pressing the Esc key.
3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Jan 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Logitech mouse problem
I assume there is no second mouse on the system and you are using keyboard commands. Try the following in the device manager..
  1. Press Control-Esc or press the Windows key on your keyboard to bring up the Start menu.
  2. Using the up arrow key, highlight "Settings."
  3. Right arrow key to "Control Panel" and press the enter key.
  4. Use the arrow keys to highlight the System icon and press the Enter key.
  5. Use the right arrow key to select the Device Manager tab. (For Windows XP/2000 , use the right arrow key select the "Hardware" tab. Now use the tab key, select the "Device Manager" button and press the enter key.)
  6. Use the "Tab" key to select the "Computer Icon" at the top of the list of device icons.
  7. Use the down arrow key to highlight the Mouse icon.
  8. Use the right arrow key to open the mouse icon and verify there is a mouse icon that states, "HID-compliant mouse," and another entry that states the name of your USB device.
  9. If there are any errors reported on these icons by exclamation points or red X's, highlight these icons using the arrow keys and "Tab" to the "Remove" button and press the enter key. (For Windows XP/2000 , highlight these icons using the arrow keys and then press Alt-A keys. From the "Action" menu, highlight "Uninstall" and press the enter key.) When the "Confirm Device Removal" box appears, press the enter key.
  10. Once these icons have been removed, use the Tab key to get to the "Refresh" button and allow Windows to re-detect the pointing device. (If u r using Windows XP/2000 , press the Alt-A keys. From the "Action" menu, select "Scan for hardware changes" and press the Enter key.)
  11. Use the arrow keys to open the Mouse icon again and verify that there are no errors reported.
  12. Power down the computer system and restart Windows.
Apr 16, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Installing Win XP, F8 key to agree to EULA wont respond
Check for an F Lock key on your keyboard.
By pressing it, it should activate your F Keys and F8 should work as advertised.
Nov 18, 2007 | Computers & Internet
Fujitsu Siemens AMILO Pro V8010 Notebook Logo
402 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
