Question about Sharp CD-BA150 Shelf System
Need to remove slide tray to get at the optisal system.
(sharp mini system cd-ba-150) Whats the secret for removing the slide tray to get at the optical mechanism?
    President:
  • 1,348 Answers
It has a rotating gear with a stopper on it.there is a limit switch to tell the motor to stop.if you do not set the timing properly,it will be out of sync and will not work.the best way is to remove the top cover,load it to play with no disc in it and you will see the pick up.do not look into it ,it is a laser beam,and can damage your eyes.if you want to clean the lense,get it to load,no disc to come up and then unplug it and clean the assembly
Posted on May 23, 2009
I have a Sharp CD-C2600 3 disk mini component system that has not been used for a few years. I thought I would dust it off and use it, however, the cd tray will not stay closed. Fixable?
I just checked online you will need to remove the screws from the back which should allow entry to cd player. It sounds to me like you need to put small amount of lubricant on the trays release slides. They should in theory be quite obvious once you open system up. Something like wd40 spray should surfice.
Jan 15, 2017 | Sharp Audio Players & Recorders
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
I CANNOT GET THE CD DRAWERS TO OPEN ON MY SHARP MINI COMPONENT SYSTEM MODEL CD-DK890N
Chances are the loading mechanism is out of alignment. Very hard to realign this mech. even the manufacturer just replaces the entire mechanism when repairing.
Dec 08, 2013 | Audio Players & Recorders
I have a Sharp CD-DK891N Mini System. The 5 tray CD system will not play any CD's, there isn't anything stuck in any of the trays. How do I get the CD 's to play??? Any help would be appre
Get a CD cleaning kit and follow instructions, if no change the laser pickup assembly will need to be replaced, far cheaper to buy a new player.
May 12, 2012 | Sharp Audio Players & Recorders
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Sep 17, 2008 | Sharp CD-BA2100 CD Shelf System
Error code 0203
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
Mar 26, 2008 | Sharp CD-BA2600 CD Shelf System
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
Dec 15, 2007 | Sharp CD-BA200 CD Shelf System
179 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
