Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Gas coming out of exhaust is it the carburetor and why
Murrays riding mower briggs and stratton
  • Dan Todd May 11, 2010
    If gas runs out of your exhaust does it continue to run out when you turn the key off? It could be a stuck float in the carb bowl. Until you find out I would definitely turn the gas tank valve switch off.
    Does it still start and run? If it does, have you checked it on your finger smelling it to see if it is condensation or gas?
    Has the mower been setting up a long while? If it starts, start it up and turn the gas switch off and let it run all the gas out so it will not drain back down into the crankcase.
    How long has this been happening? We need more info, please.
    Sirwriter
  • Dwain Pippen May 11, 2010
    Is this happening while it is sitting still and is there gas in your oil?
  • 284 Answers
Carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
Posted on May 25, 2009
I have a Murray riding mower model 40504x92A need to know what kind of carburetor I have
What do you mean what kind of carb? If you are needing parts for it you would order them based on the engine on the mower ex. Briggs and Stratton Intek 17.5 hp or kohler courage 22hp.
Jul 20, 2016 | Murray Garden
Murray lawn mower model number m20300 trying to locate carberator
Murray M20300 is produce by Husqvarna (HOP) group. Its product number should be 96114002702. It uses a Briggs and Stratton engine model number 9T602-5019-B1.
The carburetor PN is 795475 which include the 795083 diaphragm and gasket. This diaphragm and gasket is most problem found when the carburetor fails to operate. Considering the cost of the carburetor kit it is just cost effective to purchase the whole carburetor replacement kit.
You can purchase from online vendors that sells Briggs and Stratton parts or purchase local from a local shop that deals with Briggs and Stratton engines.
Mar 26, 2015 | Murray Garden
Why would i have oil/gas combo coming out of the valve cover on my 17.5 hp briggs/stratton riding mower. what should i look for?
check for gas in oil remove dip stick if does replace needle and seat in carb put in new oil replace fiter if have one try this ,let me no what happend
Sep 03, 2014 | Garden
I have oil/gas combo coming out of the valve cover on my 17.5 hp briggs/stratton riding mower. what should i look for?
check for gas in yuor oil if does replace needle and seat in carb then chang oil filter if it has one make sure to clean bowl well on carb let me know what happen
Who stocks spare cutter decks for a murray sentinel 30" ride on mower
check with a Murray or Briggs & Stratton dealer for avalibility, Have model I can check for ya. Murray went out of biz and was took over by Briggs 5-7 years ago. If ya find one you may not like the $$
Sep 04, 2011 | Garden
Scotts model 46572x8 need to see a drive belt diagram
The lawn mower you have was manufactured by the Murray Company, which has been purchased by Briggs and Stratton. For parts and service, you can contact the Murray Division of Briggs and Stratton at 800-258-5011.
Hilary @ Scotts
Aug 21, 2011 | Garden
I can't find any thing on my my riding mower
This machine was made by Murray who is no longer in business. Briggs and Stratton purchased a majority of the company and a lot of the parts can still be purchased through Briggs. I do not see a parts diagram for the (b) series but I was able to find one for an (a) which is a year older machine. I have included a link for the parts diagram of it. Murray 425614A Murray 42 Lawn Tractor 2002 Diagrams and Parts List...
Jul 14, 2010 | Briggs & Stratton Garden
I have a Murray Riding Mower won't start. I took
clean fuel line and carburator out real well with a good quality carb cleaner this should do the trick,take the carb apart to do this check needle valve where gas comes in to the carb bowl it is alot of times plugged up
May 29, 2010 | Briggs & Stratton Garden
I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 08, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
1,498 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
