Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
Audio input/output problem
I have HP Pavilion dv2000 laptop, whenever i insert a headphone jack an tried to listen audio through headphone, the audio still comes out from the laptop speakers, how am i suppose to listen only through the headphone and mute the laptop speakers, i tried different headphones but the audio still comes out from the laptop speakers. besides, i couldn't find the audio software installed from where muting could usually be done and i do not have the motherboard driver as it has been lost and i haven't made any backup. the solution i wanted is when i connect the headphone, the laptop speakers should automatically mute itself, so that i can only hear from the headphone and not both.
  • 59 Answers
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
Posted on May 23, 2009
2 Suggested Answers
ebay312
  • 118 Answers
SOURCE: audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
My HP Pavilion dv2000's Speakers
Sound cable is lose inside computer.
Nov 19, 2017 | HP Pavilion dv6000z Notebook
I have a problem with my headphone jack wont work, and there is no headphone volume controller in mixer. I have a HP pavilion dv2225 (dv2000 series) with a mcp51 High Definition Audio (nvidia) sound...
You say that you get sound from the speakers but not the headphones,, what i advice you to do is going to control panel, go in hardware and sound, in device manager, look for your sound driver for example, sound max, once you found them right click and uninstall, afterwards restart your pc, that should fix your sound by reinstalling your drivers, if that doesnt work i recommend going to control panel sound settings and switching sound outputs..
Jun 05, 2010 | Computers & Internet
No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Feb 04, 2010 | Dell Inspiron 1545 Notebook
Res.sir, i have a hp pavilion dv2000 laptop in this laptop headphone not work
first of all check whether the port is working correctly or not. For that use any other headphones. If they are working then ur present headphone set is gone. Or else if it is also not working then goto control panel -- sound and audio devices and then go to volume --advanced and increase the volume of all the devices present there..and correctly configure Sound Effects Manager which is present in the control panel ..in that u can configure the type of speakers u use or headphones ..there u adjust it to headphone..then the job is done..
Jul 07, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Audio/sound problems
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
How to connect mixer an amp to laptop?
How is everything hooked up?
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
Mar 20, 2009 | HP Pavilion dv9000z Notebook
Acer Aspire 3620 laptop screen is coming off and goes black
sounds like a hardware problem....if u know how to assemble the laptop.it will be easy for u to fix that problem....all that things are connected to the mainboard..re insert all the cables what is loosen...regarding the headphone jack,if you have an extra jack you can replace that by resolder.
Jan 01, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP PAVILION ze2000 speakers not working
First of all, make sure that the issue is with the Speakers or with the Audio Card of the notebook.
First, download and install the Audio Drivers of the Notebook from the link below :
ftp://ftp.hp.com/pub/softpaq/sp30001-30500/sp30262.exe
Please save the file in the Notebook and double click it after the download completes to install the drivers.
Restart the computer once the installation is completed.
Now, try playing any audio file using Windows Media Player.
If you are not able to get any audio from the speakers, try pluging Headphones into the Headphone Jack of the Notebook.
If you are able to listen audio from the Headphones, the issue is with the Speakers where you need to replace them.
However, if you are not able to listen audio either from the Speakers or from the Headphones we need to suspect the Sound Card.
Contact HP Chat support and find the Part Number of the Speakers if there is audio from the Headphones.
Sep 01, 2008 | HP Pavilion ze2000 Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
