Mac Time machine & Capsule. When I delet files on time capsule. The file seem to delet vie trash but the available space on time capsule does not increase. Eg I trashed 66 Gb but disc space stayed the same
  • 2 more comments
  • peter_carey May 23, 2009
    Thanks firesnake09 for your input. Have and had alsready tried your suggested solution. I had an old 66Gb back up on my time capsule for a pwerbook G4. The G4 is no longer used so I opened up its Bundel and deleted, by moveing to the trash all back up for the old G4, except the original first back up which is about 30Gb only. My MacPro trash deted all the file except, as I have said the original first backup of the G4. It definalty seemed to have deleted the files as it took a long time to deal with the empting the trash. Give that I deleted about 36GB one would have expected the old G$ back up to be around 30GB. However when I access the time capsule vier "Connect to Server" under "GO" and "get info"on the G4 bundel it says that the bundel is still 66GB
    What do you mean "may be that file is sosmall in kb so it not change space"
    Are you saying ny deleted fill are still there or are you saying that they appear to there. How do I regain my spce on Time Capsule
  • peter_carey May 27, 2009
    Thanks taran_2005. for your input.
    Not sue waht you mean by "So, what you need to do is only to delete this directory (with ´sudo rm -rf
    /Volumes/NAME_OF_THE _MOUNT´), and boom, your free space would be back again!"
    "ps - NAME_OF_THE _MOUNT means the actual name of your mount point…"
    Are you saying that I should type ' sudo rm etc. etc. I do not have a lot of computer knowelage. I have been useing apple since 1994. Never had the need to go right in behind the seen. Never had problem before. Currently runing MacBook Pro 15", MacBook 13" and time capsule.
    Regards
    Peter
  • peter_carey May 28, 2009
    thanks Taran. After reading you note i deleted the whole file and presto all of space came back. Thanks
  • 10,515 Answers
The problem is caused by a bad mount. When a mount process fails, the system automatically create a mount and saves the data under /Volumes/NAME_OF_THE _MOUNT.
So, what you need to do is only to delete this directory (with ´sudo rm -rf /Volumes/NAME_OF_THE _MOUNT´), and boom, your free space would be back again!
Thanks.
Posted on May 23, 2009
  • taran_2005
    taran_2005 May 27, 2009
    Let me explain you.How are you deleted the files? It sounds as though you are mounting the
    sparsebundle image and then browsing using the Finder windows, locating
    the file(s), and then dragging them to the trash. If that is true, then
    you should stop deleting files this way. It is not the correct
    procedure and could cause corruption of the backup sparsebundle image
    and make it an unreliable backup.
    The other part to explain is that when you backup using Time Machine,
    all the subsequent backups do not copy the file over and over again.
    For example, if you've been doing backups for a while and now have 30
    backups completed, unless you make a change to the file (modify, move,
    etc.), there is only one copy of the file - not 30. So by removing one
    copy out of one backup will not free any space, you'd have to remove
    all the copies and it will still only free up the amount of space equal
    to one copy of the file, not 30. Does that make sense?
    The correct way to remove backups and free up space would be to 'enter
    the time machine', browse to what you want to remove and click the
    action (gear like) icon and select the option to remove the individual
    backup (might not free up too much space) or all the copies of the
    backup (which would free up the most space). Or you can simply remove
    the entire time slot of the backup by browsing to the highest folder
    level (named after the hard drive or computer) and remove the
    individual backup. Be careful not to remove all the copies unless you
    want to remove everything.
    The above one is an example.
    Further help, let me know.
    Thanks.
    President:
  • 1,383 Answers
May be that file is sosmall in kb so it not change space.
    President:
  • 2,923 Answers
This is weird. You are right that once you delete some files, the capacity of those deleted files should become a free space for your storage. If I'm not mistaken, the capacity of your Time Capsule is either 500GB or 1TB and you are running Mac Leopard, right?
You may need to double-check the settings on your computer. To do this, please follow the steps below:
1. Apple Menu > System Preferences and then click Time Machine.
2. Check the other settings.
If all the settings are correct, unplugged the power cable from the wall outlet and plug it back in after couple of minutes (2-3 minutes). Then check the available disk space of your Time Capsule.
If same problem exist, try updating the software of your Airport since the Time Capsule is connected via the Airport. Updating the Airport helps the Time Capsule to perform better.
IMPORTANT: Resetting your Time Capsule to factory default settings erases all of the current settings and resets them to the settings that came with your Time Capsule.
Have a great day!
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
Tip
How to Recover Data on Macintosh The Right Way
As a Mac user whatever you lost files from: accidental removal, formatting, system crash, virus attack, etc., DO not panic! Now, it is at least possible to recover your Mac files as long as you follow the right steps.<br /><br />It is said that about 80% Mac users are used to deleting a file or emptied the Trash bin by mistake on their Mac computer or perform format option. Do you really think those files are really gone forever or are you looking urgently for a solution to recover and restore those important files, photos or documents that you need and which you've just deleted? So what should be the right things to do when you accidentally met this kind of problem?<br /><br />Possible to Recover files from Mac machine in such case? YES, definitely. As matter of fact, when <a href="http://www.datarescuetools.com/how-to/mac-trash-recovery.html">emptied Trash Mac</a>, used Shift-Delete to get rid of the file, deleted it from within an application or used some other method of removing it that bypassed the bin, then it is still almost certainly recoverable. The file is still not really deleted. Although the space occupied by the file becomes available for re-use by other files, it doesn't get re-used straight away so the data it contained will stay on your hard drive for some time to come and may be recovered using software that knows what to look for.<br /><br />First things first - If you have Mac machines purchased after November 2007 are installed with the Leopard operating system. One of the most important utilities of the Leopard is Time Machine. This complete backup tool can backup almost anything and everything on a Mac every hour with its unique features. Once you deleted or lost your critical files, just enter your Time Machine browser, you'll easily do Mac data rescue from Time Machine backup. If time machine has failed or you forget to set the backup, then you may need to use the third party Mac data recovery software to rescue data. <br /> <br /><a href="http://www.datarescuetools.com/mac-data-recovery.html"><b>Data Recovery for Mac</b></a> is a high-end Mac data recovery solution that recovers deleted or lost files (documents, videos, photos, archives, email and more) from HFS, HFS+, and NTFS, FAT file system volumes on Mac machines based on OS X. It can scan and find lost partitions, boot sectors and other file system components within internal Mac hard drive or external device. Incorporated with 3 Recovery Options like 'Deleted Recovery', 'Raw Recovery' and 'Lost Partition Recovery', the Mac file recovery software is a powerful yet comprehensive solution to recover all your Mac data in just a few mouth clicks. <br /><br />But you should remember: before your deleted files are recovered from Mac, DO NOT attempt to put more files to the partition as this will decrease chances of Mac trash recovery for there might be a chance for your files to be overwritten. Overwritten, it is impossible to do mac data recovery. You should be aware of that.
on Aug 03, 2011 | Prosoft Data Backup 2.0 (databackup2) for...
Tip
Possible to Recover files from Mac machine in such case? YES, definitely. As matter of fact, when emptied Trash Mac, used Shift-Delete to get rid of the file, deleted it from within an application or used some other method of removing it that bypassed the bin, then it is still almost certainly recoverable. The file is still not really deleted. Although the space occupied by the file becomes available for re-use by other files, it doesn't get re-used straight away so the data it contained will stay on your hard drive for some time to come and may be recovered using software that knows what to look for.
Data Recovery for Mac is a high-end Mac data recovery solution that recovers deleted or lost files (documents, videos, photos, archives, email and more) from HFS, HFS+, and NTFS, FAT file system volumes on Mac machines based on OS X. It can scan and find lost partitions, boot sectors and other file system components within internal Mac hard drive or external device. Incorporated with 3 Recovery Options like 'Deleted Recovery', 'Raw Recovery' and 'Lost Partition Recovery', the Mac file recovery software is a powerful yet comprehensive solution to recover all your Mac data in just a few mouth clicks.
on Aug 03, 2011 | Computers & Internet
Recover lost data
Hi
You can make use of file recovery software for mac to recover deleted files from Trash. Using this software I have recovered large number of deleted files on Mac.
Aug 02, 2012 | Yahoo Mail
Do the machines work with mac ?
Hi THERE, Summary
Learn how to set up Time Machine to perform backups, how to restore items (or your entire system) from a backup, how to use existing backups on a new Mac, and more.
Products AffectedTime Machine, Mac OS X 10.6, Time Capsule 802.11n (1st Generation), Mac OS X 10.5
Time Machine lets you automatically back up your entire system in Mac OS X v10.5 and Mac OS X 10.6 or later. Time Machine keeps an up-to-date copy of everything on your Mac--system files, digital photos, music, movies, TV shows, documents, and so forth. You can easily go "back in time" to restore files if you ever need to.PLS OPEN THIS LINK YOU GOT ABOUT THE INFORMATION.
http://support.apple.com/kb/ht1427
Aug 26, 2011 | SySTOR Systems Systor DiscMaster 202...
Accidently emptied a trash bin that contained a very import ant file. How to restore this file?
1. If you simply put files in the Trash you can restore them by opening the Trash (left-click on the Trash icon) and drag the files from the Trash to your Desktop or other desired location.
2. "Time machine" is a built-in backup tool that works with your Mac and an external drive, As the problem you described, I read it. The files deleted in Trash bin could be a different problem which Time machine can't solve. you can read this article and learn more. I hope it will help.
3. If you don't have a Time Machine backup yet, then your best option would probably be uFlysoft Data Recovery for mac software
Mac File Recovery How to Recover Lost Files from Emptied Mac Trash
Mar 09, 2011 | Apple Computers & Internet
I hook up my harddrive and printer though Apple Time Capsule and my IMac it wirelessly connect with Time Capsule. Sometime I can't locate files from my harddrive. Please help
If you have the hard drive and printer connected simultaneously through a USB hub, it MUST be a powered USB hub (i.e., one with an AC adapter). Could this be your problem?
Jan 08, 2010 | Apple 24" iMac Desktop
Recovery?
Since you are runing under Mac OS X, NO 1 choice is rely on Time Machine to recover from backup. If you do not set Time Machine, then you probably need a Mac data recovery software. But the first thing you need to take care is do not put more items to the Macintosh HD where those trashed stuff originally located. Learn more from this article recover emptied Trash Mac for more helpful information. Best regards.
Sep 16, 2009 | Computers & Internet
Creating space on external hard drive
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Apr 04, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
