Question about Mitsubishi WS-65909 65" Rear Projection Television
Will not stay on., Automatically turns off.
WS-65909 Mitsubishi 65" will not stay on after 4-5 seconds. I have unplugged the unit for several hours & tried the 'system reset switch' to no avail. Problem persists with/without remote. Problem started suddenly after @ 3 hours running. s/n; 113135 I have never used the 'NetCommand' feature. Also using; Denon AVR-2802 Magnavox MVR700VR VHS/DVD recorder Scientific Atlanta HDTV Explorer 8300 HDC
  • eriklars May 23, 2009
    I have the sam problem. My Mits WS-65909 rear projection HDTV won't stay on for more than a few seconds. I followed Slinteriors advice and held down the device and menu buttons on the front panel. The LED blinked twice followed by a pause and then blinked twice again. This pattern repeated itslef until it had blinked twice 10 times, with a pause in between each time. Please advise on what this error code means.
  • ebailey211 May 26, 2009
    I have the same problem and the repair man came out and diagnosed a code 22 (blinking in sets of 2, repeating). He then stated this was a convergence problem. I'm not sure what this means, but the repair form (he left the estimate and is coming out this morning to do the repair) reads as follows: 'Convergence repair, STK's & open pico fuse'. The repiar estimate is $420 plus tax. I hope this helps!
  • Mitsubishi Master
  • 8,617 Answers
Try pressing in both the menu and device/input buttons in together on the front of the set and hold for 5 seconds to see if the led will blink a two digit error code such as 2 blinks then a pause then two more blinks followed by a pause which would indicate a 22 error. Then let me know what the blink code was if any.
Posted on May 23, 2009
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
The t.v will not stay on after being on for about 5 seconds.
do the self check model indicated has.
when power light comes on and then goes off: On front of set press and hold both the menu and input buttons in at same time for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
This will indicate what kind of problem set has.
Let me know what error code you find and I will tell you what it means.
SD TECH
Oct 22, 2010 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
I have a mitsubishi ws-65909 - flashing 2,2. Can
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Nov 13, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My 65 inch projection TV turns off within a few seconds when I turn it on. Why? No pictures or sound.
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Nov 03, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My Mitsub. ws-65909 green power light turns on for about 3-4 seconds, then shuts off. Ideas ??
Replace Both of your STK ICs they are big black ICs will have # on them STK392-570? Call Mats for Parts 1-800-628-1118
Sep 24, 2009 | Mitsubishi WS-65909 65" Rear Projection...
We have the dreaded blinking green "timer" light after we unplugged the WS - 65909. We can't get it to reset according to the owner's guide instructions.
The Digital module must be repaired. It is not booting up. When first plugged in the LED in that set will blink for 70 to 90 seconds. That is the amount of time it takes for the digital module to boot up. If it continues to blink past that time the module is belly up and needs to have some capacitors changed in it. Most reputable shops can do this in your home and average cost is between $150 and $250 depending on where you live.
Jun 11, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi ws-65909
I suspects you have bad convergance IC's
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
476 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
