Question about EliteGroup P4M800PRO-M2 (V2.0) Motherboard
PC does not boot, no beep, no monitor output but fans and lights work.
PC does not boot. No beep whatsoever. No monitor output. But fans and lights are on. What's wrong? The RAM is absolutely ok. But I suspect the hard-drives are the ones causing this problem. No matter how many times I remove the CMOS and return it back...it never solves the problem. What should I do? The power supply is surely ok also.
  • 39 Answers
Hi, The problem is mostly your Processor. Remove the fan and heat sink. Then remove your processor, and replace carefully making sure it sits properly on the pins. Hold it down with your finger and lock the bracket. replace the heat sink and fan. Processor 775 is not like 478 where the pins sits in the holes of the base. 775 rests on the pins of the base and tends to shift if not seated properly. This's what happen to my set.
Posted on Jan 30, 2010
Usually if everything inside the case is working (from best you can tell) and the monitor is not coming on it's one of two things.
1.) The video card is bad, if you are using on-board video this isn't too highly likely. To test just replace the video card if possible with any other compatible video card.
2.) The CPU has gone bad, in general I find that this is the most common scenario. Obviously to test you would need to replace the CPU.
Posted on May 23, 2009
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
NO DISPLAY on screen but processor fan is work
If it seems like the computer booted up all the way except the screen is blank.
If so try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok and works, then the video card inside the computer is good, but the original monitor is bad. If the Borrowed monitor does not work, then the video card inside the computer is bad.
If it does not seem like the computer booted up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Jun 09, 2012 | Intel Computers & Internet
Mouse keyboard and monitor dont work upon power up
If it seems like it booted up all the way except the screen is black try the steps below.
Either the monitor or the video card inside the computer is bad. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your video card is good, but your original monitor is bad. If the Borrowed monitor does not display then the video card inside the computer is bad.
If it does not seem like it booted up all the way try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Jun 07, 2012 | Dell Studio 540 MT Pentium DualCore E5300...
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Asus p5lp-le no display
If it seems like the computer completed the boot process but the screen is blank, try the steps below.
The problem will either be the monitor or the video card inside the computer. Connect another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad and the video card is good. If the Borrowed monitor does not work then the video card inside the computer is bad.
If the computer did not complete the boot process then try the steps below.
Jun 05, 2012 | ASUS Computers & Internet
Desktop runs but won't boot
Normally if the hard drive is bad you will get some type of message on the screen.
If it sounds like it is running but the screen is blank, then try another monitor. Maybe the monitor is bad. Try another monitor. Borrow a monitor from a neighbor, friend, relative or co-worker and put it on the computer. If the borrowed monitor works, then your old monitor is bad. If the borrowed monitor does the same thing, then your video card is bad.
If it does not seem like it booted up all the way then try the steps below.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
May 09, 2012 | HP Computers & Internet
Won't boot
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Computers & Internet
Computer not working
What do you mean not working? What is it not doing?
Mar 30, 2012 | Toshiba Computers & Internet
We experienced a power outage today, our Gateway GT5408 was in Stand-by mode when it happened. After our power was restored, our computer will turn on with the cooling fans running and the leds light up,...
It could be the monitor died or the monitor cable is loose at one of the ends ( check both ends are connected and tight ).
try another monitor or if you have a newer TV with a vga monitor connector try your TV. (you will need to change the TV input to computer or to VGA )
Sep 09, 2010 | Gateway GT5408 PC Desktop
EliteGroup P4M800PRO-M2 (V2.0) Motherboard Logo
835 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
