Question about Samsung Televison & Video
What can I do to fix the flipping of the screen from snow to prog
This past week I was watching a TV program and my TV started acting up and the screen was flipping quickly from snow screen to program and back to the snow screen. And the sound is like a muteing sound . The picture when it does appear is very clear and sound for that moment is clear. I dont know what to do my TV is not even a year old.
    President:
  • 1,348 Answers
The tuner is getting a weak signal and that is why the vertical sync signal is weak and the picture is rolling .check the cable on the back
Posted on May 23, 2009
My pictur on my tv looks like it is snowing how can I fix it
try to watch a movie that doesnt contain snowing...
If you mean white pixels for no reason on the screen while whatching the tv it can be caused by unstable power, or tv signal.
try to remove tv cable, then replug it so the picture will clear
Apr 13, 2013 | Televison & Video
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
2004 Samsung RB1955vq fridge cooling/freezing problem
I think that the thermostat breaker in your compressor is getting tired.
Please before spending your money in the PBA clean all the guts of your refrigerator from the dust that accumulates .
Then try it and let's hope it's fixed,
Thank you.
Jul 23, 2009 | Samsung Refrigerators
No monitor
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN or DON'T
5) START IT UP...
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE.Hope that will do. Otherwise you can re-install windows if you have a Windows CD.That will definitely solve the problem.There might be problems with VGA Resolution [if you have used the laptop with some other monitor or TV] or driver. For installing Windows Do Google Search.
Jun 30, 2009 | Dell Inspiron 6400 Notebook
Channel skipping in Sony Rear projection KP-EF41 TV
is the channel flipping always happening at set intervals? Or, just randomly? Try replacing the batteries in the remote. If that doesn't work, start looking for other sources of IR(infrared). In some rare cases, direct sunlight on the TV will get it to do strange things.
Jan 31, 2009 | Sony KP-EF41 41" Rear Projection...
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Records snow/static - intermittently
Intermittent problems like this really suck.
I have a simular problem on my Toshiba DVD recorder. Once in a while it just doesn't record anything at all.
Unfortunately, there really is no solution. It sounds like a glitch in the unit to me. Wether or not it's present in all the units of that model or just yours, only Panasonic knows for sure.
Feb 14, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Ilo Flat screen
if your tv is on warranty take it back to supplier for another.if the warranty has expired have a tech repair your tv the Audio,or power is defected good luck.
May 14, 2007 | iLO 2600 Television
Televison & Video Logo
172 people viewed this question
Henry  Thomas
Henry Thomas
