Question about John Deere 4020 Gas & Diesel Tractor Radiator
1969 John Deere 4020 won't start
When I turn the key, can hear the relay click but it won't start. I shorted across selenoid to start w/screwdriver. Do you have any suggestions on other possible cause(s) of the no-start problem?
    New Friend:
  • 14 Answers
Replace solonoid
Posted on May 29, 2009
I have a 790 that has been great and starts on the dime all the time including in the cold weather. The other day went to use the tractor after it has sit for about 2-3 months. Tractor started right up as usual, 1 hr use turned it off went back to start and nothing, including it would not turn over. Found a lose battery cable but had to jump start it with my truck. It started and ran for about 30 minutes and while idolling it shut down. Since then and charging the battery it will turn over but not fire. What I have done: Cleaned the air filter. Disconnected the air intake and tried starting but did not work.
Drained the fuel filter assembly and wiped it down but did not replace filter. FIlter does look dirty. Still did not start.
disconnected hose to pump to see if fuel was there and it was .
Currently draining the old fuel and replacing it but I do not think this is the problem since it was running fine before.
Any suggestions?
Posted on Apr 03, 2011
Lx173 John Deere wont start. starter motor will not run to start eng you hear only solenoid engaging starter drive. have tested motor on bench. started blowing fuse since solenoid replaced.
You may have a bad key switch or you have a short in the wiring somewhere. Also check the Magneto's for proper gap. If they are loose they will stick to the flywheel and prevent motor from turning and could blow fuse.
Oct 21, 2016 | John Deere Garden
Need a Harmonic balancer puller for 4020 John Deere tractor
Your local Jd dealer can get you service guard tool for that specific pulley or they can advise you on how to remove it. Some dealers may loan you the tool. Just depending on dealer.
May 19, 2015 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
Wiring diagram 1969 4020 john deere deasel tractor
Usually there are forums specifically for a brand and even models. I would seek help there. Also look on Ebay. Have you asked a dealership? They might even scan and send you images.
Aug 27, 2013 | Vehicle Parts & Accessories
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
JOHN DEERE 4020 SETS FOR A COUPLE DAYS AND WONT START, BATTERY DEAD
You either have a dead cell in the battery which is draining power or something is on draining power. On a tractor there is not much to be left on, so check everything. It is more than likely a dead cell and a new battery is in order. To check the alternator to see if it is charging, start the engine and with a volt meter check the voltage at the battery. If it is reading between 13.5-16 volts the alternator is more than likely good. If any lower than 13.5 it is defective.
Dec 31, 2009 | John Deere 4020 Gas & Diesel Tractor...
I have a 1969 John Deere 4020 that is cold blooded. It turns over fast, but won't start without being pluged in or using ether below 70 degrees. What are the potential problems?
Cylinder Compression Low, Valves worn ... not seating properly, valve stems.
Injector nozzles worn ... dribbling rather than precise squirts, injection pump worn.
First and easiest thing to do: pull all nozzles and have them tested, pull the injection pump and have it rebuilt and re-calibrated.
*NOTE: you can pull these, but are components that proffessional need to rebuild and calibrate. Truck shop, or farm tractor shops have places that specialize in this type of work.
If it is gasoline, I would look towards pistons, rings, valves.
Nov 12, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Starter won't turn over,I shorted selenoid with screwdriver and it kicked in selenoid and started,,ok bad selonoid,,I just replaced with new starter and selonoid,,still won't kick seloniod in,,shorting...
That wire may be coming from a relay so you may need a service manual to find which one it is.
BTW, to save frying all of your screwdrivers, applying 12 volts for a moment to the terminal with the smaller gauge wire will cause the solenoid to operate as it was designed. Shorting across the main solenoid terminals lets ~ 100-200 amps flow through your screwdriver which isn't even a very good conductor.
Even a light clip lead to the coil terminal of the solenoid could handle the lower current that flows there.
For purposes of doing several different engine tasks, I made up a momentary pushbutton switch contraption housed in a plastic film canister, put 6' wires and heavy clips on it so I could 'jiggle' an engine into the next cycle.
Oct 12, 2008 | Buick Skylark Cars & Trucks
John Deere 4020 Gas & Diesel Tractor Radiator Logo
1,539 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
