Question about MTX Thunder 5-Channel Amplifier 895 Car Audio Amplifier
Trying to find the right FET to replace burnt up ones with
I'm trying to find a FET for my amp but i dont know which one i need or where to get it. I checked the local Radio Shack. They had some but I'm not sure if they are the right ones. On the board is reads FET1002 and FET1001 they are burnt up. On them is a part number which is 75339P. Then under that reads N2 36 F DN
  • saleen_2001 May 24, 2009
    they went bad do to a bad ground and as far as i can tell that is the only thing bad. wont really know til i fix them.
  • Perry Babin May 11, 2010
    HUF75339P
    Try:
    mouser dot com
    President:
  • 1,348 Answers
Hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
Posted on May 23, 2009
My defroster went out and im trying to see if its a fuse but i dont know what fuse to look for with out a manuel can u send me a picture of the fuse
www.dodge.com/download/pdf/.../2010-Avenger-OM-2nd.pdf
Copy and paste this link and it will show you all about the fuses.
Jan 08, 2015 | 2010 Dodge Avenger
How to repair a palomar 450 fet. Ld amplifier.
sniff around inside ,see if there is the smell of burnt wire or other componants.If it turns on see if there is a componant that starts to smoke.If it does change it and see what happens.this is called trouble shooting.
May 15, 2014 | Palomar Redman Cb Stop Hd 450-fet Hd 10...
Put new alternator on 2000 jimmy envoy 4.3 now I get 7.3 volts my instrument panel flickers. had no preveise problems. put old one back on and now it does same thing. how do I know what wires to trace
I dont know if this will help but my sister had 2001 envoy and had similer problem we found wiring harness next to exaust was burnt and stuck to it. we pulled it off and blacktaped wires. this fixed her car. good luck
Feb 14, 2012 | 2000 GMC Jimmy
Replacement fet
http://www.mcmelectronics.com/product/483513047059 But this is a transistor NPN and a small one at that for only $1.39. A FET costs about $35.00. 9322 121 46687 is the power FET for that set. Location #7301 Description STW13NB60. http://www.partstore.com/Part/Royal%20Philips%20Electronics/Philips/932212146687.aspx IS one place, or Google your part# and see what comes up. Hope you find what you need. Good-Luck. Let me know if you need something else.
Dec 08, 2008 | Philips Magnavox 51MP392H Rear Projection...
Battery drill part
cep6060r or irf540 google em
Jun 21, 2008 | Dryers
Trying to buy a power fet for beko28416nd
What is the number of the FET that youre needing. Let me know I should be able to help you.
Apr 17, 2008 | Televison & Video
JVC RX-ES1SL 5.I
1: In most cases there are two FET`s gone you can use a normal IRF 530 but cut the heat sink from the FET do it with a pincer not with a grinding machine! (static electricity!). Before you switch on the set pay attention for the following parts!
2: The two coils that are mounted under the metal housing on the main board look of they have a other color if so they are burnt Check also the SMD parts under the main PCB.
3: The two SMD Elco`s that are mounted on the little PCB they have in most cases a high ESR. The value must be under 1 I thing that all the troubles you can have with this set are coming from this two elco`s (100uF 16 volt.)
4: look for a short cut on this little PCB pay attention to the two SMD gates. Measure the S/C over the +5 and +12 volt lines and check both PCB visual.
5: You must bring in a lot of heat to remove the both IRF`s use a good flux and do not fear the heat they can have it.
Because you must use a big Iron there is the danger to damage this aluminum layer check visual after you have solder the two FET`s all the connection with the smaller parts measure them with a Ohm meter. This was the fault in mine case there was a open connection to one of the gates of the FET`s
Feb 10, 2008 | JVC RX-ES1SL Receiver
Blown amp
hi, try connecting the power b+ and gnd and remote turn on cables only (dont connect rca input or any spks), if amp doesnt turn on you will have to take in for repair. no need to buy new amp, coz problem could be a burnt pcb track or even a faulty remote or FET circuit.if amp turns on then connect other cables slowly and monitor the power lite as you do connections. you may have a faulty spk load that will cause amp to stay off or in protection mode. cheers
Jul 22, 2007 | Kenwood KAC-7202 Car Audio Amplifier
MTX Thunder 5-Channel Amplifier 895 Car Audio Amplifier Logo
421 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
