Question about Canon PowerShot A95 Digital Camera
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
My camera is about 2 years old. Recently I was trying to take pictures and the shutter button seems to be stuck in the down position. When I try to move the zoom lever in or out, a picture is taken automatically. The camera will not let me look at pix in review mode either or get to any of the menus. If I press the shutter button a pix is automatically taken. It seems to be stuck in auto mode, but I'm unable to do anything. Taking batteries in and out and taking memory card in and out doesn't help either.
  • Anonymous Mar 29, 2014
    CANNOT GET CAMERA OUT OF REVIEW MODE
  • Canon Master
  • 4,738 Answers
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Posted on Dec 08, 2007
SOURCE:
For several years my C-3020 zoom camera has worked fine. Suddenly, now when I take a picture, the picture leaves when I snap the shutter. Always before the picture remained on the screen so I could see if...
In the camera menu, there should be a setting for "review" to allow you to set the number of seconds the picture remains on the screen. Also, you can always review the pictures you've taken by pressing the review button on the camera...it's usually a button with an arrow that points to the right.
Jan 21, 2011 | Olympus Camedia C-3020 Zoom Digital Camera
When i turn my camera on the screen is black. when i take a picture the screen remains black and when i press review of the picture i took that is black as well. is that a back light problem or something...
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 21, 2010 | Kodak EasyShare C330 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
When trying to take a pic, I only get a black LCD screen. I can see the icons and I can play pictures back on the review mode. Any idea what's wrong? Thanks!
Try pressing the DISP button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place to save batteries.
That normally fixes the problem of a black screen, but if it didn't, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 02, 2010 | Canon PowerShot SX110 IS Digital Camera
Cannon sd1000 lcd screen black. Can review pictures, but cannot take new pictures.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2010 | Canon PowerShot SD1000 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Lens won't open
Dec 07, 2009 | Canon PowerShot S2 IS Digital Camera
I have no display on my lcd screen when taking pictures...but do have display when reviewing pictures. HELP!!
First confirm that you didn't accidentally press the DISP or DISPLAY button on the back of your camera, manually turning off the display. (Press it once with the camera turned on just to make sure). If that didn't fix it...
Aug 03, 2009 | Canon PowerShot S51S Digital Camera
Displays icons but won't register pictures
First make sure that you accidentally didn't turn off the screen by repeatedly pressing the DISP button to cycle it on and off. If that didn't fix it, and if your camera is less than 1 year old, call 1-800-OK-CANON to arrange free warranty repair.
If your camera is more than a year old, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black Screen and takes blank pictures
It sounds like a stuck shutter. As the camera is less than a year old, Nikon should fix this for you for free under warranty. Contact them.
For others that experience this with cameras that are out of warranty:
Jun 27, 2009 | Nikon Coolpix S210 Digital Camera
Canon PowerShot A95 Digital Camera Logo
415 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
