Question about Linksys EtherFast Cable/DSL Router
Unable to browse internet on second pc on a ppoe network
Just set up a ppoe network with router. pc1 has windows vista and pc2 winxp. I'm able to see both computers on the network, but i'm unable to browse the internet on pc2.
  • 611 Answers
If the firewall is on then off it if any proxy server is there then off it then try it after then also so not working then restart the computer and go for the start then run in that type ping google.com -t if this is showing reply then your internet its working
Posted on May 23, 2009
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
Cant get two computers connected to the internet
There are to many ways try this,
Switch on the router.
Connect both pc's to the network.
NOTE Down The pc's IP Address.
Example:-
Pc1:- 192.168.1.20
Pc2:- 192.168.1.21.
If you want see pc2's hard disk on pc1.
Open the 'run' window and then type :-
\\192.168.1.21\c$
This will take some time.
It will ask you for your Pcname\Username & Password. Type them and click ok.
Your Done!
If you want to see pc1 on pc2 type:-
\\192.168.1.20\c$.
if fails
you can use remote destop application that is built-in in Windows based computers to share resources between 2 computers, and even totally control 1 remote computer:
See this link: http://www.microsoft.com/windowsXp/using/mobility/getstarted /Remoteintro.mspx
Mar 12, 2010 | Buffalo Technology WHR-G54S Wireless...
How to configure the WGR614 v9.using cable router to pc1 to pc2?
Well, if you are using wired connection from the router to the pc2 then you need to check for the cable connected between the router and this computer. You may try changing the cable and check if that resolves the issue.
For wireless connectivity, please perform the below steps to configure settings
1. Right click on My Computer icon and go to Manage.  2. Go to Services then go to Service and Applications.  3. Double click on Wireless Zero Configuration.  4. Change the Start Up Type to Automatic and click on Apply  5. Click on Start and press OK to close the window.  6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 7. Right-click on the wireless Network Connection icon and select 'Properties'.  8. Go to the 'Wireless Networks' tab .  9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'. 2. Right-click on the wireless Network Connection icon and select 'Properties'.  3. Click on the 'wireless network' tab. 4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK. 5. Right-click on the wireless Network Connection icon and select 'View Available Networks'. 6. Look for the SSID (aka Network Name) of the Wireless router or access point.  4. Highlight thee SSID from the list that you want to connect to.  5. Type the security Key here and click on the 'Connect' button.  6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 17, 2010 | NetGear WGR614 54Mbps Wireless Router...
Network to include: PC1 that stores all shared files and is connected to printer and scanner. PC2 that can access shared files, printer and scanner via PC1. PC1 & PC2 are hard wired to the router...
You have to configure password for WAP to access the network. For this go to router management and configure the WAP password.
Revert back for more assistance.
Feb 01, 2010 | Computers & Internet
Computer says connected to internet,, wont display page
usually routers are setup using DHCP... on your second computer. try going to
start, control panel,  networkconnection,  "your LAN connection",\ properties Internet Protocol (TCP/IP) (should be checked)
Obtained Ip address automatically should be selected
Obttained Dns server automatically should be selected.
then click OK, OK to save settings...
if your router is not setup as a DHCP,it would require you to setup your ip address manually... let me know if this dont work, so  i can help u setup manually...
if it helps, try comparing the settings of your pc1 and pc2 (the network connection settings)
Feb 02, 2009 | D-Link DSL 604+ (DSL-604+) Wireless Router
2 Eth Cards one for Internet & one for LAN
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Apr 25, 2008 | Computers & Internet
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
Linksys EtherFast Cable/DSL Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
