Question about Alpine Car Audio & Video
Alpine usb "device error"
Just installed the deck and the radio works. But when switched to usb inlet it reads, "device error"?
  • Dick
    Dick May 11, 2010
    The 2008 Alp 200 motorcycle has no USB port. You have mistakenly installed in the ignition key slot.
5 Suggested Answers
SOURCE: Screen says searching when iPod connected to Alpine CDA-9847
Check your ipod to see if it is shuffle mode. Alpine doesn't document this but they have a bug that causes the problem that you describe. If the ipod is in shuffle mode the Alpine gets confused.
Posted on Sep 29, 2008
CRTN
  • 716 Answers
SOURCE: dimmer wire connection from aftermarket delco harness to alpine
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
Posted on Mar 11, 2009
  • 21 Answers
SOURCE: newly installed alpine resetting
Chevy stock speakers are 8 ohm. You should change out the stock speakers. Or at least dissconnect the back speakers and see if cd player still overloads and shuts off.
Posted on May 22, 2009
  • 3 Answers
SOURCE: usb device error
The cord might likely the problem. The iDA-X100 will only recognize iPods if you use an original Alpine USB cord. Using any other cable won't work. I had this problem when my Alpine cable fell apart and stopped working. I thought any other cable would work, but that's not the case.
Posted on Sep 21, 2009
Alpine 9886 with sirius interface
This problem sounds very sirius. Sorry, couldn't resist, but "siriusly", the song alert feature is supposed to be something you select yourself, so it locates a particular song whenever it is played on the service. Do you recall setting this?
Are you using the Alpine KCA-SC100 tuner or another?
I would try resetting the radio too.
Dec 13, 2013 | Alpine Car Audio & Video
Alpine IVA_D900R parking brake bypass
first off i must say this feature is put here by the companies for a reason they dont want to pay millions to the families of people hurt and so the blame gets bumped down to you. so be carefull so you dont have to spend the rest of your life paying for the damage.
when you install the deck you need to get the (pink) wire grounded. this is usually the color of the parking break check on the deck. it is looking for a ground coming from the parking break. usually this can just be bypassed by tieing into the ground on the deck.
Hope this helps
Jul 08, 2009 | Alpine Car Audio & Video
Usb device error
Jul 06, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Alpine deck ipod not working
Why don't you stop complaining and buy another iPod. They're only a couple hundred dollars.
Apr 05, 2009 | Alpine Car Audio & Video
Aipine ida x 100,usb device error
Are you using the original Alpine iPod USB cable? If not, that could be the problem. The iDA-X100 will only read iPods using the Alpine cable. Otherwise, you get a "USB Device Error."
Mar 08, 2009 | Alpine iDA-X100 Car CD/ MP3 Player
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Dec 30, 2007 | Alpine CDA-9851 CD Player
No audio from cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go. The same goes if your have an aftermarket amp driving your speakers.
Sep 23, 2007 | Alpine CDA-9885 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
199 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
