Cyberguard SG300  Firewall
Problem for Cyberguard SG300 (00852503000366) Firewall
Cyberguard SG300
By sgex on Oct 19, 2007
How do you open port 25 on a Cyberguard SG300 firewall?
Best Solution
posted on Nov 15, 2007
Helpful)
Recnef
Rank: Wiz
Rating: 89%, 77 votes
From the main configuration screen select Network Setup, and then click on the Connections Tab. In the tabline below that click on Aliases.
At this point you input the Alias IP address and the netmask and add it, selecting port 25. The firewall now knows that it is to forward all traffic on port 25 to the computer that has the IP address you put in.
You should be aware that doing the above opens a direct access point into your network! Port 25 is the port used for SMTP (Sendmail) and it is the most vulnerable and most hacked service on the Internet! You should seriously consider not doing this.
A better option would be to goto the DMZ tab and configure a DMZ net on your firewall - you will need to obtain a second routable IP address from your ISP to do this though. By creating the DMZ and then routing port 25 to a machine inside the DMZ you isolate the machine running SMTP from all of the other machines inside your protected network and so make a compromise much less likely.
All of the systems inside your protected network will still have demand access to the machine in our DMZ, but the machine in your DMZ would be unable to initialize access to the protected network, which is a much safer setup.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Cyberguard SG300 Firewall
Questions and Unsolved Problems for Cyberguard SG300 Firewall
Do you recommend Cyberguard SG300 (00852503000366) Firewall?
Answer
Answer
Powe went down and we are now not able to access thenet throug the sg300. I can connect via laptop... (More)
Answer
i neeedd some help tryin to unlock my schools net nanny is there a program or some thing
Answer
can you help me connect my remote location to my headquarters each one running a sg300 unit
Answer
I want to connect a SG300 VPN to my Charter Cable Modem, what is the flow chart to doing this, do I... (More)
Describe your Firewalls problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Firewall Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
