Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Timer light blinking green
We have a Mit wd-52725 rear proj dlp. we had a power surge. we tried system reset, but the green light is still blinking.
  • Mitsubishi Master
  • 8,617 Answers
You need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Posted on May 23, 2009
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Blinking green timer light, tv will not turn on even after unplugging and resetting
The repair kit called the V26 Chassis DLP DM / Power repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the instructions on cd.
Oct 26, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a WD-52725. When I came home tonight I had noticed that the power had went out at the home. The timer light was blinking green. I do have a surge protector. I tried reset and turning the power off...
Thats a common problem caused by weak caps on the DM and Power boards. When the power goes out the caps drain then cannot recharge so the syeady blinking timer light will happen. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the replacement caps and the CD with repair instructions.
Aug 20, 2010 | Mitsubishi Televison & Video
Blinking green status light
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Mar 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light blinks constantly
you can get the V26 DLP DM repair kit at the following link which should repair that isue. The kit contains the capacitors and the CD with instructions.
http://www.tvrepairworld.com/
Jul 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd-62725 rear proj green timer light will not reset
you need the V26 DLP DM repair kit at the following link. The kit contains the replacement capacitors and the cd with instructions.
Jul 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
282 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
