Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Unable to enter faxes while the machine is either sending or rece
Bought a used 4750e. Freestanding, not conected to computer. When the machine is busy either sending or receiving faxes, I am unable to enter any new faxes to be sent from memory. I have used a Brother 2920 and it does this fax entry at all times whether online or not.
Any suggestions???
Thanks
  • 105 Answers
Turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
Posted on May 27, 2009
Turn off error correction mode for Brother 4750e
I found this video I have embedded below which claims to instruct you on how to achieve this.
Mar 13, 2015 | Brother Intellifax 4750e Laser Fax Machine
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Broken paper guide and difficult fax input.
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Speed Dial Setup on Brother IntelliFax 4750e
pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Fax%204750e-5750e%20User%20Guide.pdf
Apr 03, 2009 | Brother Office Equipment & Supplies
How to send the same fax to several fax numbers?
it's called "broadcasting". open your owners manual, turn to page 7-3, and begin following the directions. quite simple, but too long to explain here.
hth,
razors
Jan 09, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Won't receive or send
Try hitting Menu * 2864 (it should say maintenance) then 91 then 99
This will reset the fax machine without erasing your settings. It should clear it up. If it doesn't work after a few tries, you have to hit 0 instead of 91 and that will reset the entire fax machine to factory defaults.
Feb 20, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
