Today i filmed a bit for my spanish project on my camera but when i uploaded it to my computer and played it in windows movie maker it made a stuttering sound like my computer froze on me and it continued and froze again and again until it ended...when i play it on quick time it plays with slight stuttering but not alot...what's wrong with my camera? is it my computer? is it my sd card? do i need to do some formatting? help?
SOURCE: need to download software for canon powershot sd 600
If you plug in your camera via USB to any computer, you should be able to access the card in the camera and transfer the files to the MY PICTURES location. You can also download Picasa which will do the same thing.
If you must use the software that came with the camera here is the site:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=12913#DownloadDetailAct
SOURCE: memory card error in powershot SD1100
Try a retailer near you to see if they will allow you to test your camera with a SD card from a display camera.
Good luck, I hope this helps!
Gom
SOURCE: video playing in fast forward with no sound
This is a really simple problem and easy to solve. Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen). This will change the settings from TIME LAPSE to STANDARD. There are actually 6 different modes but the best one for normal videos is STANDARD. There is a HIGH RESOLUTION setting, however these record fewer frames per second (fps) so whilst the quality is better per frame, there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera, so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
SOURCE: Canon PowerShot A620 Camera wont upload to Computer
Use a cardreader to download your pictures.
