WASHER FILLS WITH WATER AND DRAINS IT BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
Depending on where you live, you may be able to purchase a timer for your unit at a local Lowe's or home depot i suppose. i know, in my general area, Lowe's and home depot are open till 6pm ctr..
You can also click the link provided above to order your timer on line if you chose.
no problem, glad to help:)
are there ny clicking sounds cumin form inside th unit when it is trying to agitate and spin?
Any humming by any chance or, dose the unit just shuts down?
HI, Does it drain while filling? Check the drain hose and make sure it is higher then the level of the water in the machine.
Please let me know so I can assist you further.
Thanks
Vic
It is possible the lid switch. While it is filling, try and lift the lid to see if the water shuts off. Try the same when it is draining. Let me know if it shuts off in either case please. look where the lid switch actuator goes into the hole and see if the lid switch lever is there.
These are ideas to start with.
Vic
Thanks
mod WBXR2060V1WW
the washer starts and click on the cycles but skips the agitating and the spinning. Just fills the tank with water 2 times and 2 times also drains it out
No it does not drains while filling. It actually clicks on every cycle refilling tank during second cycle and that all it does
I tried solution 1 and the lid switch is there and looks like it is working but does not shut off the process of filling the tank nor the draining.
If I go for solution #2, do you know if there any parts stoers open oon Sundays?
Thank you guys so much.
I'm very lucky to have found this website
Changed the timer assembly and did not fix the problem. keps on filling tank the timer advances clicks on cycles, drains but not agitating nor spinning
Do you have other sugestions?
Thanks
whats the model number?
