Question about HP PRINTER,DESIGNJET 500 42'' InkJet
HP designjet 500 - system error 2110
First got not enough memory to transfer to spool message on vista laptop when attempting to print 36"x58" image in coral painter X - tried multiple custom page sizes then left alone for several hours.
came back and printer read ready - I tried to get it to unload the roll paper in order to try to do a sheet - but got message system error 2110
severe error: 0 x 3010002
task: + mech
file: sequence. c
line 758
I was able to get printing 24" section of this image
previous owner had a 24" roll loaded on this printer when I purchased it
    Novelist:
  • 125 Answers
Hi urlink:
This is your problem:
System Error: 21:10
Problem
Description:
Service Station failure. The possible cause could be:
1. The steps counted by the Service Station motor are not consistent
with the expected length of the current movement.
2. The Aerosol Fan has reached its maximum current limit.
3. The Service Station motor has shutdown because of blockage.
8-52 HP DesignJets 500 and 800 Series Printers Service Manual
Service Station and Aerosol Fan
Removal
NOTE Refer to the table on Page 8-4 for information on screw types.
1.
Perform the Service Utility "Unlock
Carriage" - Refer to Page 4-22.
NOTE Switch off the Printer after
performing this Utility.
2.
Remove the Right Hand Cover - Refer
to Page 8-7.
3. Manually move the Carriage out of
the Service Station.
4. Disconnect the Service Station and
Aerosol Fan Cables (connectors P5
and P9) from the Interconnect PCA.
You will need an HP certified technician to service this product.
Hope this helps
Posted on May 24, 2009
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
My HP laserjet 1300 has something blocking the printing process... it spools/pending for a long time then an error msg comes up. Its like a document is caught somewhere in the spooling process but not...
The last time I had a problem like this with an HP laserjet the problem turned out to be the need for increased memory in the printer and replacing a faulty memory module. Check your memory modules in that laserjet and make sure you aren't overloading the printers ability to process the information.
Sep 22, 2011 | HP LaserJet 1300 Printer
HP Designjet 500 24-in Roll Printer error message 2110
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
Hi We have just recently bought secondhand-age
RAM RAM RAM...Thats the key here, Your Printer needs more RAM your PC needs more Ram... As much as you can fit in both. You see a Print job must be spooled, the only place it can, fast enough, is in RAM Memory, so if you have BIG files you need heaps of RAM especially in the printer, thats why it can take 32MB RAM, see? To "Print" a MB of data... you may need up to a triple that of scratch space.
Feb 04, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
try processing the file in the PC instead
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Jan 16, 2009 | HP LaserJet 4350 Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
HP PRINTER,DESIGNJET 500 42'' InkJet Logo
2,343 people viewed this question
Seeker5211
Seeker5211
