Question about HP Pavilion dv1000 Notebook
Laptop keeps shutting off. DV1490US. There is power in the case but not in the screen. I press the on button fo a while until all the lights go off inthe laptop and repress the same button. Sometimes light comes on the screen sometimes lights onlaptop lit up but nothing on the screen. Can hear fan working and all all the time. I keep repeating the process. If it works, laptopstays on for a while somestimes.
  • HP Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 23, 2009
How do I get out of Safe Mode?
Hi Claudia. I found this.
I found Please remove leather case on your kindle before performing the steps below.
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or Shutdown. If it prompts for Shutdown then please shut down the device and power it back on.
That should fix the problem.
If the answer to your question was informative and helpful, please show your appreciation for my efforts by clicking the green Accept Answer button right below my first response.
Thank you for choosing Experthelp.
Safe mode turns on when you shut down the kindle while the volume button is being pressed down. Solution-Restart your kindle by holding the power button until the screen shuts off. Make sure that the volume button is not being pressed while you restart your kindle. Then keep pressing the volume button, about 10 times to unstick them then turn on the kindle. Safe mode should turn offand how you go into it.
and I found this
Jan 17, 2016 | Amazon Kindle Fire HD
My computer keeps shutting down irreglarly
Hey Henry,
Try reseting your PRAM and SMC.
Here's how to reset your PRAM:
  1. Shut down your machine. Yes, all the way down, not sleep or logging out.
  2. Press the power button and then press command-option-p-r. You have to make sure you get those keys pressed before the gray screen comes up or it won't work.
  3. Hold those keys down until your Mac reboots again and you here the startup chime.
  4. Let go of the keys and let your Mac reboot normally.
For SMC:
  1. Turn off your machine
  2. Keep the MagSafe adapter plugged in.
  3. Press at the same time shift-option-control (on the left side of the machine) and the power button
  4. Let go
  5. Turn your machine back on with the power button.
Nov 16, 2013 | Apple MacBook Pro Laptop Computer with...
Kindle Fire
Press and hold the power button for fifteen seconds or so. If it prompts whether you want to shut down, ignore it and keep the power button pressed until it shuts off. Release the button, then press and hold for a second or two until it starts to reboot. Does it reboot and operate normally now?
Jun 11, 2013 | Tablets & eReaders
How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
Close out any software currently running on your Toshiba Satellite L305 laptop.
Navigate to the laptop's "Start" menu and choose "Shut Down."
Hold down the laptop's "0" key and press the power button.
Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
hope this helps
Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
I can't shutdown my laptop.
If you can't shut down normally (using windows), you can press and hold the power button until the computer shuts down. You can also remove the battery.
Make sure to save you work or anything that is open before you perform a hard shut down.
Feb 28, 2011 | Lenovo Computers & Internet
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
My laptop wont close down
Press and hold the power button until the computer shuts off. If that does not work, remove the battery. In either case when you start up again the computer will probably show a message screen and suggest a scan for problems.
Oct 16, 2009 | Computers & Internet
My laptop seems to have gone into sleep mode, and I cannot get it back out.
Plug the charger into your laptop and then keep the power button pressed until it completely shuts down. Then press the power button again to turn i t back on.
Mar 29, 2009 | Computers & Internet
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
HP Pavilion dv1000 Notebook Logo
133 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
