Question about Intel Computers & Internet
Pc has no sound. Volume control says no mixer device installed.
Bought my pc from a friend. later i noticed the 3.5 audio port is not functioning, hence could not use my headset. the package came with a Pleomax 2-speaker plug-in to the usb port. there was audio in said speakers. i checked the device manager, it says Realtek high def audio driver not installed. i tried several actions to make the on-board audio to work, including buying a sound card (whose driver keeps failing to install), updating win xpro. in the process, i lost even sounds from the usb audio. opening the volume control, i get the "no mixer device installed" is the error message.
    President:
  • 814 Answers
This sound like a operating system corruption. You will have to install the windows disc and try to do a repair of the system. If the repair fails and you cannot get the sound to work. You will have to reinstall windows. These corruptions happen due to downloading programs that do not work well with the operating system. You can try removing all the new programs, you installed before the problem appeared.See if that returns the sound operation to normal. If not you can also try a restore windows to a earlier set-up with the windows restore point. If Have done a back-up of your system.This may also restore the sound to normal operation. If all this fails you probably have a bad motherboard that has lost the functional operation of the sound circuits. You may need a new motherboard. If this is the problem. You can go on the motherboard maker website and look into the frequently asked questions and troubleshooting sections and see if this is a known problem with you motherboard model. See if they have a solution. I hope this information helps you with your problem.
Posted on May 23, 2009
This is the active mixer error message... --------------------------- Volume Control --------------------------- There are no active mixer devices available. To install mixer devices, go to Control Panel,...
NO active mixer is one of the volume control, your sound card or your audio port is not installed. try to install again your motherboard installer and locate for the audio of it of for the soundcard. Then after that restart and when the sounds come then you successfully installed it
Jan 10, 2010 | Computers & Internet
Tip
No Sound, No Volume Control, Mixer not Found, No Sound device installed?etc etc,
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots....visit my support page.
all the best...
on Dec 23, 2009 | Computers & Internet
Compaq CQ60 speaker problem
Hello....
all the best...
Dec 26, 2009 | Computers & Internet
I try using realtek ac97 audio driver for win xp 3 but it stated device cannot start error code 10
"No Active Mixer Device installed".....
The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall.
Dont do any thing further....shut down pc/laptop
Then...u need to go into system BIOS
1 - Start PC/Laptop...press DEL or F1/F2/Insert/Home key...this selection of key to go into BIOS depends upon ur type of PC in some Del key works in some F1/F2 key works to go into BIOS....you need to do this before the WindowsXP screen appears....get into BIOS...
2 - Scroll/go to On Board Peripherals...press enter...next screen....
3 Look for
A- "On Board audio"
B- "AC97 audio" or any thing that says "Audio"
C- "Look for anything that says "MIDI" with some numbers 301,205 etc in [ ]
just Disable all the above by using PgUP PGDN key
Press F10 and chose Yes to save the setting in BIOS
or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...
It should NOT......Re-appear.....if it does then do the above process once more.
U are now all set for the next move....
U need to spend just 1$ to buy this product on Ebay...you can buy any similar product of your choice but it must have the audio and mic output ports like this one has...and must be able to connect to your USB port of your PC/Laptop
This below image and product name is only for your info, you can buy any such similar product available in your area....but it's must have the Audio and Mic output ports like the one on the image below and must be able to connect to your PC/Laptops USB ports...
"USB 2.0 Mic Speaker 5.1 Audio Sound Card ADAPTER #9340"
You can Google it and locate it where you can buy...
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...
Dec 14, 2009 | Computers & Internet
Driver installs ok and detection also but no sound.i have try to put also in the volume control the sound getting out from behringer.doesn t work
"No Active Mixer Device installed".....The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Guys....the solution's very simple....This is a sure shot solution...101% guarantee...Just do this...
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall. Dont do anything further....just shut down pc/laptop
3 Look for
A- "On Board audio"
just Disable all the above by using PgUP PGDN key Press F10 and chose Yes to save the setting in BIOS or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...It should NOT......Re-appear.....if it does then do the above process once more.
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...01be335.png
Nov 03, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
From my pc's motherboard 845 GLM audio port audio as well as mic is not functioning, but it seems to be all right with internal configuration. How can i get best solution. please guide me...........
3 Look for
A- "On Board audio"
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...61d861a.png
Nov 03, 2009 | Computers & Internet
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
3 Look for
A- "On Board audio"
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...3781d32.png
Oct 25, 2009 | Compaq Audio card Sound Card
No sounds,no active mixer devices,no audio devices,cant use volume control
uninstall the sound driver in the device manager and download the latest audio driver from the support site and install it.
Apr 25, 2009 | Dell Dimension 3000 PC Desktop
Plugged in headet mic and it is not read as being plugged in
Hi Chibiagogo,
i have a slight idea that your mic might be on mute, have a look in your "control panel - sound and audio devices" there is a "volume" tab... just below that there is an "advanced" command button that will open your volume mixer, if the "mic" volume control does not show then you can enable it... check if it is set to mute ( please note this is for windows xp)
If this is not the case then you can also see in your "device manager" the your "sound, video and game controllers" has the "media control devices" installed. If not then maybe download the latest driver for your sound card or audio device on your motherboard.
Hope this was helpful or at least points you in the right direction. Best of luck friend!
Foujoubeen
Mar 18, 2009 | Dell Inspiron 1501 Notebook
Installation of audio mixer
friend If you want to use a sound card there is a driver along with it when you buy one. Intalling is easy, just follow instructions prompted by your screen, just agree with its terms and conditions and there you go. If your PC's motherboard has an onboard soundcard you just have to configure it. Go to your computer's start click it, then go to settings and click Control Panel. Inside Control Panel click Sounds and Audio devices, then go to VOLUME, SOUNDS, AUDIO, and VOICE then adjust the volume of each. Remember to plug in your headphone to the right input/output devices.
I hope i have solved your problem!
P.S. Don't forget to rate me.
Jun 18, 2008 | Sony JACK, HEADPHONE Computer Speakers
Computers & Internet Logo
499 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
