Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Belt will not stay on hoover windtunnel s3765
  • 10,865 Answers
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
Posted on May 23, 2009
Removing beater bar from Hoover canister vac sweeper head
click here > http://hoover.com/file/402/ for the manual it will give you full instruction on belt change on page 7
Jan 08, 2013 | Hoover S3765-040 WindTunnel Bagless...
The carpet brush won't revolve on the Hoover S3765. After 5 months I replaced the belt and the salesman gave us model 38528-036. Is this correct? The rotating brushes are not hard to turn; it's just...
this is the part for the belt, 38528036. you can get it at sears website or service center. also make sure you clean the caps on the side of the brush. take them out and remove hair and dirt. put a little or mineral oil and install them back.
good luck to you.
Feb 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
No longer pick ups
You need to replace the belt. It won't pick up if the belt is worn or stretched. Here is the belt you need:
Hoover S3765040 Belt
Feb 25, 2010 | Hoover S3765-040 WindTunnel Bagless...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Need help with Hoover S3765-040 WindTunnel Electronic Bagless Canister Vacuum. The belt that rotates the brush keeps slipping off. what to do?
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Sep 03, 2009 | Vacuums
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
436 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
