Question about GE (PSS26MSRSS) Side by Side Refrigerator
Maytag model (MTB1950GR) tripped off the power switch and smell
My refrigerator power switch tripped off suddenly and there was a smell around (not burning smell though but electric). Freezer and fridge compartment not cooling after this incident. Both outiside fan and inside freezer fan working. Is this something big expense to repair? what to do?
  • gdesai May 23, 2009
    Vic, thanks. How much it cost if i need to replace it? can i do it or i need repair specialist?
    yes, it smells near the compressor. How much it cost if i need to replace the relay? can i do it or i need repair specialist?
    President:
  • 1,136 Answers
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
Posted on May 23, 2009
  • Victor
    Victor May 23, 2009
    HI, You can replace it. Get em the model# and I can look it up for you.
    Vic
  • Victor
    Victor May 23, 2009
    Hi, Is there an revision number next to the model #? I might need serial # too. There are two different part#'s for the model
I have a Maytag GC2227 and it is tripping an RCD. If the fridge temperature setting is switched to off the RCD does not trip but as soon as the temperature setting is adjusted the RCD??
Refrigerators are never supposed to be on GFCI devices, they will tend to "leak" a bit of current to ground during defrost and "trip" when there is no real problem... You can test this theory by plugging the machine into a two-prong adapter to see if it still exhibits the same symptom, the only problem I have seen in home refrigerators that can trip a 20 amp circuit break is a seized compressor that is drawing "locked rotor amperage." By design, the start relay/overload should interrupt power before this happens... Hard Start Kit RCO410
Jul 04, 2016 | Maytag Refrigerators
Model mtb1950gr. Freezer stopped working. Fan is blowing cool air up there, but everything is completely thawed. Refridgerator part below it seems to be working fine. Vaccumed back.No change.
Your defrost may be stuck on. Cool air is not the same as freezing air. Frost free freezers use less than freezing air passed over and through the food to warm any ice crystals and move the moisture out of the freezere.
Apr 03, 2016 | Maytag Refrigerators
I have a Maytag model MZD2766GE refrigerator/freezer I have noticed that around the edge of rthe refrigerator where the gasket is it is staying quite warm.....Is this normal?
Yes, this is normal. There is a heater that runs around the outside to keep it from sweating.Some models have a switch on the inside of the fresh food section so that you can turn off the heater.
Mar 21, 2011 | Maytag MZD2766GES Side by Side...
Trouble shooting a maytag dryer that just stopped working all of a sudden. Model# HYE3658AYWl
Check your breakers to see if they tripped. If your sure you have power to the dryer, then check the door switch. You should hear a click from the switch. If no click is heard, replace switch with this part.
Nov 28, 2010 | Maytag Dryers
How do i replace the light switch in my RTD1900D?
I am guessing that you mean the door switch, so: remove power then using a sharp knife slip it under the switch flange and, pry up gently then: do the same thing on the other side and all around the switch until it comes out; remove the spade wire connectors
Jul 22, 2010 | Maytag Refrigerators
Initially power tripped within 5mins, cleaned
you may have some thing like a "spider" shorting out the power inside the motor maybe,,,but one thing is certain you do have a short in it some were if its popping trips out
Feb 21, 2010 | Refrigerators
Burning Smell
sounds like the motor is fried or seized up, which would explain that smell.
Feb 17, 2008 | Refrigerators
Kitckenair fridge
replace themostat or check gas level
Apr 11, 2007 | KitchenAid KSRA22KKSS Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
403 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
