Question about Denon AVR-484 5.1 Channels Receiver
Protection mode Hi, I just got this unit and when when I power it up after couple of seconds goes to stand-by mode with the led flashing fast. Looks like the protection is triggered. It does the same even with out anything connected to the receiver. I'll appreciate your suggestions. Thanks
  • 3 more comments
  • stbil Feb 03, 2008
    Hi Robotek,
    I'm ready for your directions with multimeter and Weller in my hands. I have some knowledge as a TV cameraman but I didn't deal with amps for more than 20y so I'm not aware of the current amps technologies. Hope for your help:)! I did check for any burn-outs on the circuit boards but everything looks normal. Does not look like abused unit. I don't have the schematics and I don't know were the control points are. It goes in protection mode at the same point ? when ?receiver? is displayed so I assume thats the trouble section. Hope for your respond :).
  • stbil Feb 04, 2008
    I just discover that -15V is actually -9V. This is out of IC102 (7915-negative voltage regulator) at R146. The +15V is +15V.
    It's OK. Were should look for this regulator. Any suggestions for retail or online store?
  • stbil Feb 08, 2008
    FixYa ! :)))
    Thank you very much Robotek!!! Looks like I'm not as rusty as I thought :). Our friend Murphy came to visit me but he is gone now :). 7915 has to be isolated from the radiator. Runs hot but probably supposed to because the radiator is quite big. There are couple R22s after the traf – R141 and 142 witch blows too in case Murphy is around. Although it may looks I did the job myself in fact you are the one! Your original post led me to this regulators. Thanks again!!! BTW if you need the schematics I'd be happy to email it to you. It's in pdf.
    Cheers
    Sorry for the spelling - it's “which” instead.
    Sergeant:
  • 201 Answers
Hey there,stbil, , there are two potential causes. One is speaker terminals have short-circuited, solution being to power down system, connect speakers properly, and start again. Second, the unit is not properly ventilated, and therfore running temps are potentially hazzardess to the system. Solution is to cool system down, ensure all vents are clear and inside of casing is clear of dust and other particles. Good Luck!
Posted on Feb 02, 2008
  • 4,102 Answers
Hi you are right it is going to standby mode due to a fault on the board its going to be some thing like blown resistor or along those lines as the unit comes on and then goes into stand by youll probably find that the blown resistor or short is going to be on or near the amp part of the board could even be near one of the outlets on the unit near the back of the board if it was something conected with a fault with thee power side then you will find it would probably blow a fuse and wouldnt light up at all but as it comes on then its more than likely a resistor.
Now the only way of finding out witch one or two has gone is by testing them and to do this you will need to find schematics so as to follow the circuit diagrammes and also youll need this for part numbers of any replacements needed.
It will be a cheap repair even if you have to take it in to get repaired.
You could try using a search engine to look for some schematics for your unit as you can often find them on the net.
But to test the resistors your going to need a multimeter and if your doing the repair yourself your going to need a decant soldering iron.
Let me know what you want to do and i can help you further ok
  • paul proctor Feb 02, 2008
    Hi check what ROBOTEK is telling you as he seems to have more knowledge with these than i do ok if he can talk you through what you need to do then follow his advice ok
  • 1,512 Answers
Yes, unfortunately the amp is going into protection mode. Protection mode is a self resetting circuit, that checks up to 7 different parameters of the amps operation initially at turn on, and then continuously monitoring for problems during operation. engagement of the protection circuit with nothing connected is generally caused by a fault internally that is producing a DC offset at one of the amps speaker outputs. It may be caused by many sifferent things. Dry solder joints are a common problem, blown output transistors, damage from overheating, also feature up the list. I can talk you through checks to do inside the amp to determine the problem if you like. You will need a multimeter and philips screw driver to go further. Its a nice amp and worth repairing... but if you have just got it, i suggest referring back to whom you got it from. For an exchange or maybe your money back. I am happy to assist you further, just ask.
  • 1 more comment
  • Graeme Ross
    Graeme Ross Feb 04, 2008
    I am going to look for a manual for this to make it easier to communicate about the problem. there are some things to do first that may resolve the problem
    1. First thing to do is carefully inspect(with the best lighting you can get) the PCB about the output stages for dry solder joints. If any look susect at all... blanket resolder the stages. That means every land. I often do the whole board. Murphies Law... If there is one, there may be many.
    2. Then clean the board down with PCB cleaner(or acetone) with a cutdown paintbrush to remove flux.
    3. Reinspect your work for shorts, solderblobs, or splatters. A mistake here can cause more problems.
    4. Fire it up after doing the work and see what happens
    If you are not good at soldering, then maybe get some practice in first on an old peice of gear that you can wreck. Let me know how you go. Good luck:)
  • Graeme Ross
    hey nice going. That is not an uncommon problem. Those regulators have been commonly failing for years. Check DC first. The first rule of servicing. Well done. Change the regulator and see what happens. Check how hot it is running also, there may be a short down the line of it is.
  • Graeme Ross
    Graeme Ross Feb 07, 2008
    You can get them from Farnell electronics in the UK.
    http://uk.farnell.com/jsp/search/browse....=
    pick out the device that is the same package as yours.
    Happy Fixing
    Champion:
  • 217 Answers
The fuse in it may already have blown.
2yr old Pioneer pdp-506 50" panel with seperate receiver unit
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
Jan 02, 2008 | Televison & Video
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
When DVD is plugged in the red stand-by light comes on, but when the power button is pushed the stand-by light goes out and the DVD will not come on. I have attempted to reset by holding power button down...
Hi Erickson,
First of all, thank you for posting your question here at Fixya.
I'm assuming here that your unit is Sharp BD-MPC41U.
The symptoms you've mentioned indicated that the power supply board of your unit gone to protection mode that's why the LED automatically shuts off. It will encountered once the feedback circuitry sensed malfunction and immediately turned off the unit to avoid further damaged.
To resolve the issue, you have to replaced the power supply board, part number RUNTKA699WJN0. I saw it in stock at this LINK or obtain it from your local Sharp service centers.
Also, don't forget to check if your unit is under warranty period (1 year), if so, avail it because the manufacturer will fix it for free. Opening the top cover will void the warranty.
Please let me know if you need further assistance.
Hope I helped you!
Have a great Holidays!!!
Ratings and feedback are highly appreciated.
Jdvillanueva
Dec 25, 2011 | Sharp BDMPC41U Theater System
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 28, 2011 | Sony Televison & Video
The unit will not stay on
I got similar issue and managed to fix it with excellent tech support from NAD. Flashing LED means system goes in to protective mode. Most probable reason is presence of DC voltage on amplifier out puts. In my case it was both surround amps. It had faulty resistor and a dry jpint at power line
Dec 16, 2009 | NAD T760
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
Denon AVR-484 5.1 Channels Receiver Logo
73 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
