Question about Epson Stylus CX4200 All-In-One InkJet Printer
Printing blanks I have been working on a project in which I've been printing simple addresses on hundreds of sheets. The CX4200 has been doing great, aside from the occasional "catastrophic jam" in which a page would get jammed and crinkled and torn inside the printer (the sheets are pretty thin). Each time that happened, I would dig the pieces out and, to the best of my ability, make sure that the crinkled pieces add up to the whole sheet. Suddenly, the printer has stopped printing. It still "goes through the motions," but the paper comes out blank. I've cleaned the print head multiple times, changed a couple of cartridges when they ran out of ink, run nozzle check patterns, etc., all with the same result: Though the print head moves back and forth as if it is printing, the paper still comes out completely blank. Is it possible to inspect the bottom of the print head, to see if a piece of paper is stuck there? Is there anything else that can be causing this? Any suggestions would be appreciated.
  • Kelly Cheek May 24, 2009
    Yes, I tried multiple test patterns (completely blank) followed by multiple cleanings.
    I was on a tight schedule with a job I was doing and didn't have time for this. I decided it was time to retire the old one and bought a new printer.
    Thank you.
  • Steve Greenfield May 11, 2010
    Have you tried printing a test pattern to see if the printhead works at all? Go into My Printers and right click, select Properties and look under Maintenance I think it is called. From there you can print a test print or an alignment pattern.
  • Epson Master
  • 419 Answers
If you still have the old printer a couple of suggestions that may resolve the issue and provide you with a backup.
Printhead cleaning (manual approach)
  1. Get the printhead off the parking pads and pull the power cord
  2. move the printhead out of the way to the left
  3. soak the parking pad with a distilled water or if possible a mildly ammoniated cleaning solution (the original windex is prefect for this)
  4. move the printhead back into the parking position
  5. leave for 24 hours to allow the solution to wick up into the printhead nozzles and breakdown the clogs.
  6. Plug the printer back in turn back on.
  7. Allow to do a single cleaning routine then print a nozzle check.
  8. You should now get most of your nozzles back.
  9. Allow the printer to reset for another hour and then print off a few test prints..
  10. Repeat if necessary.
This approach is much more effective than trying to use the cleaning routines which rely on the printhead nozzles only being mildly clogged.
If after all that you're still having problems, there's a thriving market for spares/repair printers so it's always worth seeing if you can flog it on ebay or similar, even if it's just for a few pounds/dollars.
Hope this helps for future reference.
Martin
Posted on May 28, 2009
My HP laser 2420d will not print. Meaning, it will not display information in the screen from print preview not will it display any of the information on paper. It prints out a blank sheet of typed...
Clarification please.
"It prints out a blank sheet of typed information"
Is it printing out a blank sheet or is it printing out typed information????? It can't do both.
"it will not display information in the screen" What screen are you talking about?
Nov 09, 2010 | HP LaserJet 2420 Printer
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Invisible printing
Lost electricity to head micropiezzo (micro pump). Usually caused by ink leakage that flow to small board at head carriage. Better take to epson service centre. If you wish to repair yourself, find similar solution on aicaxz solution.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
It is printing but no image is visible; no lights
The print head nozzle may be out of ink. Do an ink charge or 3 consecutive head cleaning! Good luck!
Jan 14, 2010 | Epson Stylus CX4200 All-In-One InkJet...
My CX4200 is printing very close to the left edge of the paper.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Epson CX4200 All-In-One PSC Printer
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Epson Stylus CX4200 All-In-One InkJet Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
