Question about Crosley Washing Machines
Crosley front load washer sometimes gives LR code
Crosley Front Load Washer Model cah4205aww
Sometimes gives code LR
Most of the time works fine.
When it gives the code LR it takes several attempts of restarting the machine to get it to go.
When it's working, it works fine with no problems.
Should I be looking at replacing parts OR
Could this be because of using inproper soap in the machine resulting in oversudsing?
Have been not using 'he' soap. I use a very small amount of reg detergent.
Also, from time to time, the machine seems to get stuck on drain and the drain pump will run and run. Sometimes, restarting the machine helps solve the problem, other times it takes several attempts before the machine resumes it's cycle.
Again, could this be because of the soap?
Thanks for your help
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Crosley front load washer sometimes gives lr code
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question &$^%^$T
Posted on Oct 01, 2010
Why is it not spinning out
Ok is it at least washing? if so may not be ur motor coupler? if direct drive. But may be a bad clutch or tranny? Even a bad belt if belt driven? sometimes even a bad door switch will not allow it to go into spin? u can check with a multi meter.
Aug 30, 2014 | Crosley Washing Machine CAH4205AWJ,...
I have a front loading machine(CAH4205AWJ) & it keeps giving me a Lr code.some times it fills with water and drains but never spins.
The LR code means "Locked Rotor". This could be due to:
  1. The control board at the top of the unit has lost connection to the motor and its control board at the bottom. Check for loose connectors. Also try 're-seating' each connector by pulling it off and pushing it on two or three times.
  2. The motor and/or control board at the bottom are shot.
Jun 18, 2014 | Crosley Washing Machines
Does not fill
nF = no fill so you need to check the water valve see it the screen is clogged or if the water valve is recieving electricity during fill mode. I bet on a clogged screen
Feb 13, 2014 | Crosley Washing Machine CAH4205AWJ,...
Crosley digital front load washer error code lr
Does it beep or flash any other lights? What was the cycle or setting it was in when this appeared?
Aug 10, 2012 | Crosley CW5000 Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer shows Lr sign on the pad.what does that
that is a locked roter sometimes caused by sudsin unit
Aug 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
107 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
jdthefixer
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
