Question about IBM ThinkPad T20 2647 Notebook
Solve IBM Laptop LCD Hinges Question
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman''; mso-fareast-font-family:''Times New Roman''; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi, my guys, Ibought two old IBM thinkpad laptops. The first one had hinges so stiff on it,they eventually broke loose breaking the laptop in 2 pieces.
but a few dayago, i get a newat
http://www.laptopbattery-usa.com/ibm-laptop-parts-ibm-laptop-lcd-hinges-c-8_88.html
Does anyonehave any idea how I can avoid this happening to the second laptop?
so i hopeanyone do not buy old one, and change a brand new, good luck!
    Sergeant:
    Champion:
  • 212 Answers
Make shure the hinges are free from dust and debris. if too tight loosen the screws up a little.
Posted on May 24, 2009
Key on IMB Lenovo ThinkPad X61 came off.
If the small plastic hinges are still attached to the keyboard, then place the key over these hinges, align it with the others keys and press down on the key until it click onto these hinges.
Aug 23, 2012 | IBM Lenovo ThinkPad X61 Notebook
How to replace backlight on a ibm thinkpad t23
The backlight fault could be caused by a faulty inverter that supplies high voltage to the CCFL lamp OR the CCFL lamp could be faulty.
The inverter is located at the bottom of the LCD screen between the laptop's hinges behind the plastic bezel surrounding the screen,
The CCFL lamp is located on the bottom edge of the LCD screen behind a reflector that runs along the bottom edge of the LCD screen. The reflector is taped to the bottom edge of the screen.
To get access to the inverter, remove the plastic bezel.
To get access to the CCFL lamp, remove the screws that secures the hinges to the base, disconnect the video cable and inverter power leads from the motherboard.
Remove the plastic bezel, it may have double sided tape securing it to the LCD screen, BE CAREFUL you do not damage the glass on the LCD screen.
Remove the screws that fix the LCD to the lid.
Now you can get access to the reflector and CCFL lamp. Carefuly remove the tape as you will need it to fix the reflector back onto the LCD.
May 10, 2012 | IBM ThinkPad T23 Notebook
Need display hinges for ibm thinkpad t40 type 23734cu
i have a pair of hinges i took off my old t40 2373 . if you want them email me at umhhmm@ gmail.com. and i could send them to you.
Jun 09, 2010 | IBM ThinkPad T40 2373 Notebook
Labtop broken hinges broke off computer still works fine just top monitor doesnt stay up snapped from hinges
here is a Ebay listing for laptop hinges for the 9400 series
http://cgi.ebay.com/ACER-Aspire-9300-9400-9520-laptop-17-LCD-screen-hinges_W0QQitemZ120549686747QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c11523ddb
You will have to install them or find a person who is handy with disassembling laptops.
1. You will have to remove the cover of the LCD screen and then you will see the hinge support assembly.
Here is a site that may assist you with the taking apart and assembly
http://www.insidemylaptop.com/fix-broken-dell-laptop-hinges-yourself/
Apr 14, 2010 | Acer Aspire 9410 Notebook
Broken left hinge on lenovo sl4oo
try going on ebay for either hinges or anon functional laptop from the same manufactuerer and find the hinges. Good luck
Oct 12, 2009 | Lenovo ThinkPad SL400 Notebook
Lenovo Ideapad Y510 Hinge problem
hinges take alot of stress as they have to be quite tight to hold the screen in a certain position, alot of laptops can have over tightened hinges and cause splitting in the housing. Hinges can quite often come loose.
Make sure all screws are present around the hinge area and if you can tighten up your hinges.
If the hinges are badly damage you can buy replacments for a few $ off of ebay
Aug 22, 2009 | Lenovo IdeaPad Y510 Notebook
How to remove the display on IBM T21 laptop
The laptop screen is secured to the laptop with screws at the hinges.
There are usually two screws per hinge. The LCD screen has one ribbon cable and possibly a power connector for the back lighting attached to the motherboard near the hinges. Disconnect these before you lift the LCD off the base, they are under the plastic panel above the function keys next to the hinges.
Feb 03, 2009 | IBM ThinkPad T21 Notebook
Replace LCD screen
All modern thinkpads are similar, you start by taking apart keyboard and top cover, then you unscrew hinges and remove screen. Here is some movie:
Thinkpad LCD Removal
Removing Thinkpad 600 Series Display - Part 1
Replacing Thinkpad 600 Series Display - Part 2
IBM ThinkPad R40 -- Fixing the black-out LCD Screen
This is not an easy job, there is risk to cause further damage to your laptop if you do not have enough experience.
May 28, 2008 | IBM ThinkPad T60 Notebook
IBM T41 Hinge Replacement
Repair4Laptop: Repairing of Laptop and Notebook LCD Displays IBM ThinkPad T41: Screen inverter replacement guide, explaining how to fix a laptop backlight problem. ... Samsung X10: (An illustrated display hinge replacement guide)
Good Luck ...........Please dont for get to Vote, Thank You.
Dec 18, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T20 2647 Notebook Logo
177 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
