Question about XRS-9400CS Radar Detector
Parts for these units
Anyone know where to look for a new speaker for my XRS? mine is blown and I cant hear a thing. it is the speaker because I hooked up a new but bigger one and it worked just fine. the mini one they sell at radio shack works, but the volume is very low with it
  • Anonymous Dec 24, 2007
    blown speaker
Call 1-773-889-3087 and speak to a Rep who can assist you with your problem, a replacement speaker will cost you about $6.00 and can be purchased with credit card or check in mail.
I know I just completed my transaction with Cobra to replace my speaker. cool beans
Posted on Jan 13, 2009
  • 51 Answers
I think the only place is through the manufacture and you would have to contact them.
Posted on Apr 16, 2008
The sound on my Cobra XRS-9700 is all distorted. It sounds like the speaker is busted. I opened it up and looked at the part number on the speaker sm-328al2 8 ohms, 0.5 watt. But I can't find one on the...
call cobra at 773 889 3087 you can purchase a new speaker for a few dollars it is very simple to install remove four screw on bottom of detector pop out the actual board and unplug the speaker and simply plug in the new one but be careful when taking apart the detector it is all plastic and there are clips that can be easily broken .
Apr 17, 2010 | XRS 9700 Radar Detector
Radar dont always work and the speaker is going out
the stock speaker is only 0.5 watt. Replaced with a .75 watt. Mine and two friends both had blown speakers by they middle of the second year of use. The only other real problem was too many false alarms in town, but better safe than sorry, bang for the buck is great-saved me more than I care to think about in tickets and residual costs. Now, it's loosing it's sensitivity, still goes off for false alarms but I got a ticket and it didn't go off (not laser) and can drive by the posted speed-readout radar things they park-mount on utility pole for "us" and it wont even go off. The other day it did, one out of 20 times (by my house) it was Ka! Luckily, the local cops use KU in their crusers so it will work until I get a new one. Too bad it's dying, planned obsolecence is only a year on these I would GUESS.
Feb 23, 2010 | XRS 797 Radar Detector
Cant hear a thing unless on speaker
You either blew speaker or broke the wires in the flip joint that control the speaker. Needs to have a new flip installed to correct problem.
Jul 30, 2009 | AT&T LG CU515 Cell Phone - Black
Cobra xrs-96 I want new speaker
Do you want to replace it with the same thing or are you looking to add an exterior speaker to it? It's a very simple task to do, you need to disassemble the unit and find the piezo speaker that's currently installed to the board. The part number will be listed on it. It may even have a manufacturers name on it. Once you've got the info, you can go to the manufacturers website and get the specifications for it. If you want the same, any electrical parts site will sell it. If you want to increase the volume look for a piezo with a higher efficiency rating. There's only 2 or 4 solder connections that need to be made on the board to replace the piezo. If you want to get creative, move the speaker to the headliner on the drivers side and run a wire to the unit with a small quick disconnect so you can take out the main unit with ease. parts will cost under 10 bucks to do it. Hope this helps
Jun 24, 2009 | XRS-757 Radar Detector
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
After about 5 min my system turns itself off
hi the problem your having could be one of a couple of things the first to check is that all the speaker wires a fitted correctly and not come out of socket as a speaker wire shorting could give you the problem your having.
The second and most likely problem is going to be a problem with the amp part of the circuit board usually a blown resistor but in your case as the unit comes on for few minutes then the chances are its just a solder joint failing on the board this causing the unit to trip out as a safety measure to stop it setting on fire.
Check the sub woofer cable is fitted properly as this is the usuall problem with you make and model let me know when you have checked all of this ok
Feb 25, 2008 | Panasonic sa-ht800V Home Theater Audio...
Need a lil ore help!!!
If the overcurrent of DC offset lights are not green, the amplifier probably has blown output transistors.
To eliminate other problems, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally (all lights green), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 05, 2008 | Sony XM-2150GSX Car Audio Amplifier
Cant hear or spk to anyone
well you're phone has a problem with its speakers. sometimes, if you drop that phone, it affects the speaker on the back of the phone. you have to tap the back of the phone slightly then it should work fine. if not, you should get a new phone from t-mobile and call them and say you're having problems with the phone. ask for a new unit. that happened to me b4 too and they gave me a new long as it hasn't been over 45 days from when you bought the phone.
Nov 20, 2007 | Nokia 5300 Grey Cellular Phone
Speaker replacement
Try to find replacement speaker on amazon, here:
Amazon com cobra xrs 9500, I hope this was helpful.
Oct 11, 2007 | XRS-9500 Radar Detector
Speaker problem o2 xda ii mini
no you need to have internal speaker replaced. You can get the part on ebay
May 06, 2007 | O2 Xda II mini
XRS-9400CS Radar Detector Logo
285 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
